Question about RCA Televison & Video
I HAVE 52" RCA TELEVISION.MY GRANDSONS WERE WATCHING IT USING REMOTE CONTROL.THEY DID SOMETHING;WHICH HAS CAUSED THE SCREEN TO SHRINK.PICTURE NOW HAS APPROX. 4" TO 6" ON ALL CHANNELS.HOW CAN I RETURN TO ORIGINAL SIZE(52")
  • 1 more comment
  • leonard8211 Oct 21, 2008
    MODEL#D52W20
    the reccomended solutions didn't work for me.
  • leonard8211 Oct 22, 2008
    SOLUTION#1 DIDN'T RECTIFY MY PROBLEM
    leonard8211@netzero.net
    Brigadier General:
  • 6,966 Answers
Offhand, I suspect that what you are watching is the PIP (picture-in-picture) display. Pls recheck your remote and determine if you can disengage/disable the PIP feature. Additionally, it may be that your main view screen is turned off or set to a Video/external source and not the tuner. Try the reset (unplug from the mains for an hour to dissipate stored energy that the unit will revert to factory defaults). Additionally, pls post back what remote was used, the original or a replacement/universal?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 22, 2008
    Genius:
  • 1,226 Answers
Refer to your user manual in adjusting the tv display.
melnavz
    Genius:
  • 1,250 Answers
The picture size of the tv has changed, there will be the option in your tv to reset it to the default factory settings, or try picture aspect ratio option this button is also present on your remote control
    Genius:
  • 2,035 Answers
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck..
  • Anand Kumar
    Anand Kumar Oct 22, 2008
    The Autoformat feature in the menu allows the TV to select the best picture format for
    the signal received.You can use the FORMAT button on the remote to see the different formats available and choose 16:9 in menu.....
    Master:
  • 763 Answers
There is settings on the menu of your remote control. it must be accidentally dis-configured. dont worry its just a minor problem besides like what youve said the remote control involve on it and not the whole tv got dis-function on the incident. if it has a manual then better to check where its configuration and i think the problem was the h size and v size settings just like in the monitor of a computer. hope that helps
thank you for using fixya
CHARCOIS
Posted on Oct 21, 2008
    Sergeant:
    Champion:
  • 331 Answers
Switch off the tv for approx 3 hours so that the tvs loses it stored data and goes back to its original state
    Genius:
  • 1,269 Answers
Try the Degauss setting. That will revert the original size of the screen. You can do it using the Remote or on the front panel of the TV, press the two buttons (left and right Volume or sometime left and right Channel) simultaneously. Also there's an Auto Convergence feature on the remote which will revert the original screen size as well.
  • RCA Master
  • 6,487 Answers
Can you please give us the exact model of this TV set so we can help you better..by the way did you try resetting the settings of your TV using the remote I believe there's an option there to reset the settings of the TV set....
I have a 52" RCA
Make sure you are connected to correct cable IF connector,Go to Menu and see if you are on Cable or Air.Then Do AutoProgramming.
Feb 17, 2011 | RCA HD61W140 61 in. Rear Projection...
The picture is higher than the screen meaning that the everyone on screen no longer has a neck. How do I fix it?
adjust the ASPECT RATIO of TV using the MENU button....remote control if an original will have a button on the remote to change ASPECT RATIO on TV....ZOOM button can cause that also!
May 19, 2010 | RCA HD52W58 52" TV
3-d Picture
The vertical deflection output chip or associated cirutry including the coupling cap and controls. Some units have vertical output transistors which can short and open the B+ resistor feeding the transistors.
Oct 11, 2009 | RCA D52W19 52" Rear Projection Television
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
RCA projection TV
are buton on remote sticking or on tv it self clean controler tap on button
Oct 07, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Help with tv
RCA controls everything from the remote control. Unfortunately you will need to purchase the original remote from the manufacturer or an authorized parts retail supplier. www.tritronicsinc.com
C-Dog
Jan 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA PIP
Put something else, DVD player, VCR or a second signal, into one of the other inputs on the unit and switch the PIP to watch that input...
Nov 20, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
267 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
