Question about Acer Aspire 5500 5570-2609 Laptop
Charging laptop hi we go camping alot where there is no power wot so ever wot is the best way to ge my laptop charged i have a car charger and a conecter so that i can connect it to a car battery would this work or will it blow up the computer .ps this is wot we used for our porable dvd player in the past
  • 128 Answers
Car battery output is 12v see if your pc charger has the same ouput voltage . if your pc charger has a lower output voltage, connecting your laptop to the car battery will definitely damage your laptop
Posted on Oct 21, 2008
Lenova tab s8 wont charge help
Hi, it maybe possibly your battery to drained flattened to the point where it cannot accept a charge from the wall charger. the best thing to do is to try and trickle charge your tablet from a low voltage/amperage connection. Either a powered on PC USB port to the charging connector on your tablet, or from a low power phone charger (5v/500ma). It has been pretty well documented that lithium batteries do not like to be drained fully & it may be that the battery in your tablet has drained so low that it cannot accept a charge from the Lenovo a/c charger.
Try a trickle charge for 8-10 hours (or longer) on your tablet & see if that gets enough charge into your battery to enable it to recognise & accept a charge from the a/c charger.
Else it replacement of charger or some hardware failure in your tablet
Oct 04, 2015 | Computers & Internet
Batterys showing full charge but when my daughter gets on in power kicks in then stops
razor hasnt been charged for a week as i needed a new charger i had 1 scooter charging over night yet still nothing , i bought a new charger its showing green on the light do i have to wait till it shows red and then wot if it doesnt still work
Dec 17, 2013 | Razor E100 Electric Scooter
My zg5 laptop battery will not power my laptop.battery is new. fully charged.
Hi John,
For the sake of clarity: the battery which will not charge/power your Acer Aspire One Netbook is the original battery that came with the Acer, is this correct?
Assuming that the answer is Yes then replacement with a NON Acer, universal battery is the only solution.
Reputable internet shops, such as Amazon, have these at around $50...
DANGER; Due to the recall of thousands of Acer (HP and others) batteries with a possible fire hazard please dispose of promptly and properly.
Best Buy has a Recycle program:
If this link does not work please Google Best Buy Recycle
Nov 20, 2012 | Acer Aspire One Netbook 8.9" Notebook
My acer emachine laptop wont charge. i think charging unit has a problem.
The best way to figure out if it is the charger or the port is to plug it into your laptop and giggle it. If it moves alot the port probably needs to be re-attached to the motherboard with a soldering iron. If it doesn't move very much then you probably need to replace the charger. Hope this helps.
Apr 11, 2011 | Acer eMachines 520-2890 Notebook
When i plug the charger in the first time it is working but when the charger is unplug the laptop is not working.
Hi Tim, As per my understanding you are experiencing issues with the laptop not working without a charger being plugged in.In this regards what I would suggest you do is see if the battery charges with the charger plugged in and in case the battery does get charged see if you are able to power on the laptop with just the battery connected and no charger plugged in.If you are able to get the laptop to turn on only with the charger connected and unable to power on with just the battery then it would be an issue with the battery not getting charge.So before you replace the battery please unplug all external devices from the laptop including the charger and the battery and without the charger or battery connected to the laptop please press and hold down the power button for 30 seconds after which please insert the battery into the laptop and see if you are able to turn on the laptop.This step is performed so that we could drain out unwanted static electric charges from the laptop.In case this step does not work please do consider replacing the battery since it would be an issue with the battery not getting charged. Best wishes for your effort.
Nov 12, 2010 | ASUS A9RP Notebook
Hi, I have a motorizr Z3 phone whose charger failed. I have run out of warranty and hence I went to a store and the guy gave me another Motorola Charger that is of 6.5 Volts. My original charger was of 5.0...
hi, you need to get the same charger if the output is to high then the phone wont put the charge into the battery as it could cause it to over heat, the best place to buy one from would be the well known online auction site you should get one from their for next to nothing and this will then solve the problem.
You know the battery is not at fault as it charges from your computer via the usb lead however the charger you have brought should still charger the battery but may cause it to over heat so to me it seems like their is a fault with the new charger. Its always best to buy the exact type of charger you had in the first place as this ensures the battery is charged properly.
What phone makers do is keep the same charge connector across most of their range of phone but as phones and technology changes they start using different batteries in their phone so they have to change the charging power to match the phones battery, so the charger you have brought is probably for a newer phone with a higher voltage battery, so you need to get the correct type of charger and this will then solve your problem.
Or if you have a car you could buy a car charger as these charge the phone alot quicker as they run off 12volt so put out more amps to the phone but keeping the volts at the correct type.
Let me know how you get on or if you need further assistance ok
Jan 27, 2010 | Motorola Mobility MOTORIZR Z3 Cellular...
Dell laptop Will not charge, brand new charger still ran on the lil battery charge that was left in it. Wondering if the part that plugs in is loose or what u may think the problem is, thanks alot!
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Dec 23, 2009 | Dell Computers & Internet
My acer aspire 5315 doesnt charge properly.
I'm sorry to say that your initial fears are correct and the pin that the adapter connects to in the laptop is loose. This is a common problem with laptop's and can be easily dealt with.
Now I'm not going to tell you to open the laptop up and de-solder the adapter (unless you want me to).
Because this is a fiddly job and you have to order the correct adapter i recommend you take it to a reputable repair store and have them replace the adapter for you, don't let them tell you that you need a new motherboard as this is not the case at all, adapters can and do get regularly get fixed and is not that expensive.
Good luck.
Aug 18, 2009 | Acer Aspire 5315 Notebook
Laptop battery wot charge to 100%
Please help us help you.....
1. Brand of laptop
2. Model of laptop
Alot of laptop batteries decrease in charge value throughout use. If your laptop is an HP it has a battery restore program with the orginal software sent with your HP laptop. It takes an overnight commitment to let the program run but it usally restores the life of the laptop battery. Another solution would to be buy a new one off ebay.
Jul 01, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
