Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
Built in speakers not working on my HP pavillion zv5000, sound only through earphones plugged in.
  • 2 more comments
  • reichard Oct 22, 2008
    thanks for the suggestions.
    I found the problem. When I place a bit of pressure on the top right hand corner the sound comes on. So there might be a loose connection to the speakers.
  • grembandilla Nov 25, 2008
    my speakers wont work either ive tried reinstalling the hardware also
  • etinoco56 Nov 26, 2008
    Exact the same problem not sound thru built speakers only thru earphones line i try diferents drivers and no luck any help Thanks..
  • Anonymous Nov 29, 2008
    same problem have to tap near the speaker to work will not stay on
    Scholar:
  • 83 Answers
Try to check your settings in the control panel sound hardware .Maybe its disconnected or there are wires that has been cut-off. Try to check also your volume settings in the task bar. Maybe its set to low or minimum volume.
Posted on Oct 22, 2008
HOW DO I GET SOUND ???
Your HP Pavilion F1903 monitor does not have built-in speakers. Your desktop computer probably did not come with speakers. You will have to plug computer speakers into the audio-out jack (green) on the back of your computer to play through external speakers.
There are also a number of USB speaker systems available that use USB both for power and for the audio signal.
Alternatively, there is probably an earphone jack on the front panel of your computer. If you plug headphones into that you should be able to listen on your headphones.
Amazon com AmazonBasics USB Powered Computer Speakers A100 Computers... Amazon com Joylive White 3 5mm In Ear Earpiece Earbud Headphone Earphone...
Jun 27, 2016 | HP Pavilion F1903 19" LCD Monitor
How can I plug earphones into this - which plug do you use?
Unless it has a plug for earphones it will not be an easy task. Most tvs only have line out (no volume control) or speaker out (rare) to plug in external speakers. Speaker outputs would be much to high to try earphones with. Line out will probably work but with no volume control unless you have it built into your earphones. You will also need an adapter to use the earphones with the line out.
Sep 09, 2015 | Televison & Video
I have an hp 2011x monitor. How do I connect earphones for sound ?
If you are asking about where to connect the earphones to the monitor, you can't. As far as I can determine this model monitor does not have an earphone jack nor built in speakers.
This is a great HD monitor, but you will have to plug the earphones into the jack (green plug) on the front (and/or back) of the computer to get the sound.
J
Thanks for using FixYa!! I provide my answer for free as a public service - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
LtCmdr Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Mar 05, 2011 | HP Computers & Internet
I am not getting any sound from the spekers, however I am getting sound through the earphone
Plugging-in the earphones physically DISABLES the built-in speakers. Unplug the earphone, to ACTIVATE the built-in speakers. Hopefully, the action of unplugging will move the MECHANICAL contacts -- if that mechanism is broken,
then it's like trying a broken light-switch -- you can flip the switch,
but nothing happens.
Oct 07, 2010 | Dell Latitude D810 Notebook
Built in Cam & Audio Problem
with help of your motherboard book let select the right (correct mdel) for the both camera and sound card. the prblem will disapper. only driver problem
Apr 19, 2009 | Computers & Internet
I got an hp pavillion zv5000 dont have power on / bios passw
Sorry to say, but I think you'll need to contact HP support on this. They have a great chat feature that they can help you on.
I just think most people will be hesitant to assist you with bypassing passwords, but I could be wrong!
Hope this helps, anyway.
Mar 28, 2009 | HP Pavilion zv5000 Notebook
I have no sound on my HP Pavillion laptop
I had the same problem, but now its solved!
Brieftly speaking, my internal speaker stopped producing sound, but when I plug earphones in, there is sound in the earphones.
Just plug in-and-out ur earphones several times (it took me 5 tries) and voila internal speakers work again!
I think there is a mechanical sensor inside the sound output (plug for the earphone) so that once it senses a plug getting in, it shuts internal speaker.
Maybe the mechanical sensor was jammed (spring problem i guess) and it still believe that u have ur earphones plugged-in. "Clogging" the hole for the earphones would allow the spring to spring back to initial position...
Hope it helps
Jan 13, 2009 | HP Pavilion dv9000z Notebook
Laptop speakers problem
There are 2 volume control buttons on the laptop. 1 turns it up 1 turns it down. Try turning the volume up. It may be up high enough for you to hear with headphones but now loud enough to be heard through the speakers.
Dec 18, 2008 | Computers & Internet
Laptop speakers working, ear phones not working
Check when you plug in the headphone the laptop speakers get off or not also see the audio configuration under control panel sound that you choose digital sound or its having channels system like 5.1 or 7.1 channels you have to configure it to headphone
Jun 29, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
1,380 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
