After i turn the tv on- right away tv is turning off by itself
  • 586 Answers
There must be problem in power supply unit.When you turn on the set it go in to the protection which means that something in the set has burn or been malfunctioning.Contact any expert nearby to find which component is not working in the power supply.
Thanks
Posted on Oct 21, 2008
RCA flat screen TV turns off by itself and won't turn back on
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | RCA L22HD41 22 LCD TV
LG TV KEEPS TURNING OFF
Kindly do not keep attempting to turn it on, as you are likely to spoil some other boards/parts/components of the TV. Look for any loose contacts in power out let, RC jack, cable and socket. In order to ensure, it is not caused by the input device, connect a DVD player
and see. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 21, 2012 | LG 50PC1DR 50 in. Plasma HDTV
I turn my vizio on then it just turns itself off
Tries tv unplug,replug it back like an hour later.By letting the tv resetting itself back to the factory setting.The tv should be working again,if have the same result.Mean the power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to by a refurbish power supply board for the replacememt.
Jan 30, 2011 | Vizio E320VL 32 in. HD Ready LCD TV
When press power on green light flashes and tv turns on but turns off right away
Try unplug,replug tv about an hour later.The tv now resetting,itself back to factory setting.The tv should work now.Not,than the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 09, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Feb 08, 2010 | Philips 27MS4504 TV
RCA L37WD12 LCD TV. it turns on and works perfectly with good picture. sometimes it just turns off by itself. sometimes it flashes rapidly before turning on. sometimes when you turn it on it just turns...
IF YOU CAN SOLDER YOU CAN FIX IT look for Bad capacitor 2200uf 25v if you see any that are puffed up on top they are bad. CK out Encompass Parts online 1-800-638-3328
Dec 08, 2009 | Televison & Video
Samsung dlp HL56A65 turns off and on by itself
It looks power board problem.
You need to get service from Samsung.
Mar 04, 2009 | Samsung DLP HL-P5663W 56" TV
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Polaroid LCD tv - model TLX-04244 Shuts itself off...
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
If your TV is less then a year old, still under manufacturers warranty.
I service these power supplies, for more info write to jah2mil@hotmail.com
Dec 06, 2008 | Digimate DGL26 Television
RCA 27F524TYX5
here is something I did find that might help?
http://www.netnoise.com/boycott_rca/rcabook2007-8.html
Dec 09, 2007 | RCA 27F534T TV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
