Question about Microwave Ovens
GE JE1540 replacement
I have a GE JE1540 microwave which has gone bad (sometimes does not start, sometimes fan keeps on after opening). I have trying to find a replacement with exactly same dimensions since this one is fitted in a frame. I tried a Kenmore, but it was just a tad higher, which made me return it.
Thanks,
Parmod.
  • cjbonner Nov 24, 2008
    I also have a JE1540 which drops into a cabinet mold. The microwave is 11 years old and needs to be replaced. Is there a replacement with the same deminisions as the JE1540 or can the JE1540 still be bought?
  • Anonymous Mar 16, 2014
    want to replace and need diminisions
  • Microwave Ovens Master
  • 9,086 Answers
This is usually caused by either a bad door switch or a loose door switch mount (which are pretty simple problems to fix).
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type from us for $5 postpaid.
If you still want to replace it, you can contact GE with your model number and they can probably tell you which model will be a "drop-in" replacement.
GE Customer Service is here.
Posted on Oct 24, 2008
GE microwave model JES1142SJ04 does not work when plugged in
Keep your oven unplugged until you contact GE. Some of their units were having problems and were starting on their own later after the owner had left, causing a fire. Not saying that is the problem, but to be safe, please contact them and Keep it Unplugged until you do.
Feb 13, 2013 | GE JE1540 Microwave Oven
My ge spacesaver microwave doesnot heat up
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 20, 2011 | GE JE1540 Microwave Oven
My microwave cooking time is complete but when i open the door microwave starts up again and doesn't stopm until you close the door
The fan runs when you have a faulty/contaminated door switch.
Check the door switcxhes.
Hope this helps.
Oct 31, 2010 | GE JE1540 Microwave Oven
I have a GE JE1540 Microwave Oven and worked good for more than 10 years. Recently it got a problem. When the microwave oven stop and I try to open the door to move out the thing from microwave oven, it...
In the cases I've seen, the fan starts operating and sounds like the oven is cooking. This is usually caused by one or more of the interlock switches being out of adjustment.
Jun 20, 2010 | GE JE1540 Microwave Oven
Microwave won't heat, appears to be on.
heatman101
jhdfs
Feb 26, 2010 | GE JE1540 Microwave Oven
Is there a replacement microwave for a GE JE1540, 16.75 deep, 12 3/16 hi, 23 5/8 wide?
Called GE Customer Service (thanks MicrowaveSvc), as they were very helpful. The replacement microwave (GE) is: JEB1860DMWW with new trim kit: JX2030DMWW. This are P/N for white, I am sure they have something for other than white. Total job took me about 5 hours (self install, moderate ability), where the final 1 to 1.5 hours was working on the final trim kit install. Couple of notes. This oven is about 6 to 8 inches deeper. The kit wanted about 1.5 inches more horizontal space than my original install, but I made it work. I had to shimmy the vertical space by 1 inch. Good Luck!!!
Jan 10, 2010 | GE JE1540 Microwave Oven
GE microwave
This is usually an indication that the magnetron has gone bad, or something in the high voltage network controls the magnetron. Any one of the following components could be at fault: 1. Magnetron 2. High Voltage Transformer 3. High Voltage Diode 4. Magnetron Thermal Cut-out 5. High Voltage Capacitor 6. Interconnecting wiring I do not advocate taking any voltage measurements inside the High Voltage section of a microwave since the voltages can be as much as 14,000 volts or higher. If you are savvy enough to attempt yourself, WITH THE MICROWAVE UNPLUGGED, you will need to disassemble the unit to get to the high voltage section and take resistance readings. The magnetron or diode are likely suspects. If the magnetron or the transformer are bad, the repair costs can meet or exceed the price of the oven. Let me know if you need further assistance.
Jul 16, 2007 | GE JE1540 Microwave Oven
Fuse in Microwave blew , now starts running when door is opened
You have one or more defective door switches, or the door switch mount is loose or damaged. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Jun 23, 2007 | GE JE1540 Microwave Oven
Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
May 09, 2007 | GE JE1540 Microwave Oven
Microwave Ovens Logo
1,507 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
