Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Nikon D40 will not focus
Suddenly, my crisp images are all's not a setting because even when I look through the viewfinder, it's blurred before I even take the image...doesn't matter which way I turn the focus lens. One way makes it super blurred, and the other way makes it fuzzy. It has never been dropped. I took the lens unit off and put it back on..that didn't help. The lens are all clean.
  • elizadanuta Nov 27, 2008
    My D40 used with either VR 18-200 or the kit lens will not focus at times. After trying over and over again with distinct focus object it works eventually for a couple of shots and then stops again. At first it was very rare and I thought it was only with VR 18-200 but the same problem happens with the kit lens. I bought it almost 2 years ago.
  • 23 Answers
On the right side of the view finder there is a little bar. Make sure it is all the way down. If it is in the up position then it will make the viewfinder, shouldn't make the images blurry though. Also make sure it is in AF not MF (auto focus and manual focus).
Posted on Dec 17, 2008
I have a question for dream3bcop.
the little bar thing worked for me. it was up for some reason, and when i put it down, my focus wasn't fuzzy anymore. so what exactly does this little bar do?
(if you want you can email me
Posted on Jul 21, 2009
Every time i take a photo with no Nikon D40 i end up with a blurred dark spot towards the cener of the view finder? what can this be?
Do you only see the spot in the viewfinder or does it appear on the photos? Could be dust on either the sensor or the focusing screen.
Jun 28, 2010 | Nikon D40x Digital Camera
When i look through the viewfinder of my D60, the
There are 2 possibilities. The viewfinder lenses are dirty or, depending on the model, there is an adjuster, right at the viewfinder, to adjust the focus of the viewfinder. It has NOTHING to do with the picture, only the viewfinder.
Oct 18, 2009 | Cameras
Ive got the nikon d40. when i take photos close up they are blurred. there r 2 settings on the focus lense one is letter a one letter m. you have to move switch to indicate one or other. camara wont take...
The letters you're referencing is the M/A (manual / auto) focus switch. The lens has this switch and operates in Auto Focus mode when set to "A" and manual focus mode when set to "M".
You have to manually focus on the subject when in letter "M". If you do not, the result will be out of focus. From your description, it sounds like the camera / lens combination is attempting to focus and operate the shutter in auto, and focusing in manual; but due to some type of damage resulting from possible mishandling, exposure to dust, dirt or even moisture is interfering with the successful completion of the process.
You could isolate the problem to determine if the cause is in the lens or camera by simply attaching the lens to another compatible Nikon camera or placing a different auto-focus lens on your D40. The problem will either stay with your D40 or follow the lens when attached to a different camera. It is also *possible* that due to numerous attempts of auto-focusing with your D40 & lens combination, that both the lens *and* the camera have been damaged. If the problem is severe enough, the problem in the failed device could cause failure in the otherwise normally working device, too.
You might be best served by contacting Nikon Service & Support below:
You also said you lost your manual. You can download the manual for the D40 directly from Nikon in your choice of English, French or Spanish from the link below:
Oct 09, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
My d40 has a image in viewfinder, will not take picture.
What lens are you using with the D40? Is it an AF-S lens? And is the Mirror Lockup on? Chech the Custom Settings menu. If mirror lockup is on, turn it off.
Feb 14, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
It sounds to me that you are using an incompatible lens or a broken one. Does this happen with the lens that came with the camera?
R 07
Certainly sounds like the mirror is stuck or even been dislodged.
Jan 17, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 shutter speed problem
The D40 will not take great photos of an indoor event without blurring or noise. You need a fast lens and a high ISO using the popup flash or on camera flash would be ideal but some of these events you can not use flash. All these images I shot with a Nikon D40. Learn to use the camera for ur events. Experiment it's all about trial and error. Ray
Dec 20, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Blur viewfinder
are the photos also blurred when they come out? if adjusting the diopter doesnt fix the issue, you might need to have your camera and lens calibrated. why the lens? its because the issue may be isolated to the lens calibration otherwise the technician will only calibrate the body.
Oct 06, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Autofocus will not work,
Camera wont let you take a picture until focus is locked, why are you using M (manual focus) if you expect autofocus to do it for you? In M mode it is up to you to focus correctly or camera will not take the picture.
Apr 13, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 LCD screen.
Since the camera is an SLR, (single lens reflex), the CCD image sensor is behind the shutter until you take a picture. Sorry, but you cannot use the LCD to take pictures.
Dec 26, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
1,066 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
