After years of great listening, the sound coming from my receiver is muffled on all speakers including the center function. I have tested the speakers on another system and they work fine. Any suggestions?
check to see if the radio is clear. If it is it may be the signal going into the amplifier. if it is muffled as well, depending if you have an Equalizer hooked to the unit. This also could cause the problem. Finally check the bass, treble balance and volume knob but turn them back and forth while unit is on and see if signal clears up momentarily. if this is the case the control knobs need to be cleaned. Also spin the connection jacks {RCAs} in the rear and see if this clears it up. If not you may have to have the unit serviced by a professional.
tuner works great for every thing tv dvd cds just ant get it to actually tune in any stereo stations...
(More)
tuner works great for every thing tv dvd cds just ant get it to actually tune in any stereo stations no static no feed back nothin. any help would be appreciated
Left speaker channel doesn't work...speaker or headphones. Occassionally get loud hiss on left side...
(More)
Left speaker channel doesn't work...speaker or headphones. Occassionally get loud hiss on left side that goes away if turn reciever off, then back on. Get headphone sound in both ears if push headphone jack only partially in headphone socket. Any ideas for self-repair? It's a Sherwood Stereo Receiver, 6/7 years old Ron
I have a JVC RX-618V that is working but I can't get the EQ to come through the receiver. Turning it...
(More)
I have a JVC RX-618V that is working but I can't get the EQ to come through the receiver. Turning it on and off has no effect. I've hooked it up properly. On most receivers you can turn it on through the receiver (I. E. VCR2/ EQ) or some other method. Short of hooking up devices directly through the EQ itself; is there some way to make the equalized sound go through the receiver? There has to be a way to do this. Thanks
