Question about AcerView 77E 17" CRT Monitor
Monitor picture is distorted
Suddenly, the screen on my monitor bounced, and now is shaped like an hour glass. All the icons are out of focus, the tool bar with the start key, clock etc. can not be seen. If I hit "proporties" or anything else, the screen bounces, and I cant even read the popups because they are so out of focus. One minute the screen looked fine, the next minute this. Can you help?
  • 31 Answers
This is an indication your monitor is on the way to failure: You can do a "degauss' which is usually powering the monitor off and then pushing the degauss button in and holding it while powering the monitor back on.
Posted on Oct 21, 2008
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
The picture on my Sony is shaped like an hour glass
There is an apparatus on the back of your picture tube called a yoke.This distributes your picture on your pic tube uniformly.If this or the circuits enabling it malfunction,then you will get distortion-namely an hour glass shape.Tv has to be trouble shooted.
Feb 27, 2011 | Sony FD Trinitron WEGA KV-27HS420 27" TV
No power in the Monitor
Sounds like a fairly drastic fault, possibly in the power supply section. Probably not worth fixing with the cost of new LCD screens, but maybe worth asking at a local repair place.
Apr 06, 2010 | AOC 7F 17" CRT Monitor
My screen doesent fit and it is hourglass shaped it is driving me nuts
The problem is called "pincushion distortion" and happens because of the way CRT monitors work. There is circuitry in the monitor to correct the display, but it's not working in your monitor. Often this is because of bad solder connections to transistors in the circuit (they get pretty hot sometimes and can cause the connections to degrade). It can also be due to failure of those parts.
If you are comfortable working with electronic soldering and want to try your own repair, open the monitor and examine the board for bad connections. Repair any that are grainy or obviously cracked. Typically the parts that need resoldering are mounted on metal heatsinks so you have a place to start looking.
I don't recommend paying a shop to repair this. New 17-inch LCD monitors are so inexpensive today that it's better just to replace the CRT one.
Apr 14, 2009 | Compaq QVision 171FS (White) 17 in.CRT...
My screen suddenly gets distorted.
Test your laptop by connecting its video ouput (base of the computer at the back) to a known working monitor. Then power on the laptop and see if the known working monitor behaves the same way your laptop's monitor does. That will narrow down the possible causes.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
The screen flickers into hour-glass figure.
It's the tube going out. You need to replace it. If you want to stay with CRT monitors, you should be able to pickup a used one for around $10.00 on Craigslist.
http://www.craigslist.org/about/sites
Nov 24, 2008 | E-Machines eView 17f3 17" Flat CRT Monitor
1800FP image distorted
this is a little known porblem Dell has. Dell is not tell anybody.
I don't know if this is going to fix the monitor for the long haul, but it should help in the mean time.
grable the frame of monitor with both hands, apply some pressure, not too much (you will break the glass). change location and do the same thing. the screen will come back at certain location, when you apply the pressure to the frame. this is because some connection inside of the frame is coming loose with time.
good luck
if that doesn't fix the proble, please post.
Oct 17, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Emachine monitor
you need to reexamine your display controls ...look for the icon that resembles the hour glass and then attempt adjustment
Dec 07, 2007 | E-Machines eMachines Monitor E15T4
Sony E530 focus (?) problem
I think it can solve with this way:
Press Menu on the front panel of the monitor. Then press OK button and go down and go to COLOR : PRESET. Press OK and go down. Press IMAGE RESTORATION.
My E530 monitor is more clearly, now.
L.E.
Sep 23, 2007 | Sony Multiscan E530 (White) 21" CRT...
AcerView 77E 17" CRT Monitor Logo
170 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
