Question about Sanyo NVM-4050 GPS Receiver
Clock reset and cant find satellite
Every time the unit loses power I have to reset the clock and I have to reset the switch several times before the signal is acquired. This is becoming a very annoying problem. Now I have sent several E mails to the customer support and they do not offer any real solution.
To shutoff the unit hold down the "Menu" button for 2 seconds. Using the power switch on the bottom shuts off all power including the clock.
Posted on Dec 13, 2008
You never have to set the clock. As soon as the unit gets the GPS signal the clock is set to that location's time. BTW, the switch on the bottom turns all power off ... and you can't charge in that mode.
Posted on Oct 27, 2008
I have had the same problem. I just notice the power switch on the bottom of the unit. I believe if this one is used it will not lose power. The other power button is probably for a standby mode.
Posted on Oct 26, 2008
How to fix the clock of 2015 Mazda3 which loses time
check your fuses, your losing full time power to the clock
Oct 22, 2015 | 2015 Mazda 3
Why is my toshiba Satellite P-850 clock loosing time
It *might* be
- that the "CMOS battery" (normally a coin cell about 13mm in diameter) is dead, in which case you should replace it.
- The crystal which stabilizes the RTC has drifted.
- If this problem has always occurred it may be the that the RTC chip is defective, but this is highly unlikely, and even less likely to have developed a fault with time.
- if you connect to the internet frequently (several times per day) the above can be ruled out (I think).
See for example (just one of thousands) http://www.makeuseof.com/tag/3-reasons-windows-computer-loses-time-date/
Search the internet on terms similar to "real time clock in pc loses time" for more ideas
28.July.2014
Jul 28, 2014 | Toshiba Satellite Computers & Internet
Clock Losing Its Memory
Our oven clock does the same thing every time the power blips, but we live way out in the boonies and expect occasional problems. Do your lights blink too? Check with your neighbors to see if they have power problems. If this is a chronic situation, contact your power company to see if they can repair the situation.
Sep 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Change Clock - Logitech Pure-Fi Elite
hold the src button left of power along with button to the right power.a model number will appear once it does let it disappear and the unit will go into reset. set the language, 12/hr, 24hr etc and the time. :)
Dec 13, 2008 | Logitech Pure-Fi Elite High Performance...
GE Spacemaker Microwave Clock inop
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
Oct 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Power cut and now cant reset the clock
We flipped off the designated breaker to the oven and turned it on again. We were then able to reset the clock. This has happened to us several times.
Apr 21, 2008 | Fisher and Paykel AeroTech Double OD302...
Setting the time
On the back of the clock - left hand side if you've laid it down on it's face - is a row of switches. You need to start the time set-up with the clock having been unplugged so there's no time set in the memory.
Now, to those switches: The first (from the left) is DST = Daylight Savings Time - right now you'de set this to "ON."
The second switch is Time Zone: PST, MST, CST, EST (Pacific, Mountain, Central, Eastern). Set the switch to the time zone you are in.
The third is just the brightness.
Now, to set the time itself:
1 - Turn the clock face back up to where you can see it.
2 - LOOK AT THE CLOCK - LOL! This is an atomically set clock - you shouldn't need to set the time. The atomic clock bounces off of satellites all around the world. There is literally little to no "dead zones" for the clock, so you should never have to set your clock - just set it up like I state at the beginning.
Good Luck!
Mar 16, 2008 | RCA RP5420 Clock Radio
Cant set time
Rondart
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
On the back of the clock - left hand side if you've laid it down on it's face - is a row of switches. You need to start the time set-up with the clock having been unplugged so there's no time set in the memory5.gif.
Good Luck!
Mar 10, 2008 | RCA RP5420 Clock Radio
Don't know how to set the time/clock.
Setting the Clock
Before operating the unit any further, first set the clock built
in this unit.
• When the unit is turned on with CD or tuner selected, press
DISPLAY first to show the clock indication.
1 Press and hold PROGRAM/SET
for more than 2 seconds.
The hour digits start flashing on the
display.
2 Press 4 or ¢ to adjust
the hour, then press
PROGRAM/SET.
The minute digits start flashing on the
display.
3 Press 4 or ¢ to adjust
the minute, then press
PROGRAM/SET.
If there is a power failure
The clock loses the setting and is reset to “AM 12:00.” You need to
set the clock again. If the batteries are inserted in the unit, this has
no effect on the memory.
To show the clock when CD or tuner is selected
Press DISPLAY.
• Each time you press the button, the display changes the clock
indication and the normal indication alternately. (Operating the
unit while clock indication is displayed change the display to the
normal indication.)
Feb 04, 2008 | JVC 10 Watt CD Boombox with AM/FM, Dual...
Clock loses time
All memory on the n35 is powered by the n35 - if it goes completely dead, I usually leave it for a few weeks for the battery to completely flatten then check hard reset switch is off and recharge.
Dec 30, 2007 | Acer n35 Pocket PC
Sanyo NVM-4050 GPS Receiver Logo
155 people viewed this question
Top Sanyo GPS Experts
perdue40
Are you a Sanyo GPS Expert? Answer questions, earn points and help others
