Question about Compaq Computers & Internet
Mouse pad over heat's and the cursor go's wild on the screen, complete loss of control of cursor, is the cpu below the touch pad? this is on my notebook by compaq presario v6000 /
  • 284 Answers
It doesn't really matter if the cpu is located directly under the mousepad. Other things inside your notebook can produce heat. You will probably find that a fan inside the case isn't working.
Often the fan does not come on until the heat builds up so it is possible that the fan might be ok and the sensor that detects the heat may be broken.
A friend of mine told me that his internal fan wasn't working so he went out and bought one of those pads that you sit your notebook on. The pad has fans built into it. I didn't think this would be enough to draw the heat away but it worked for him.
Otherwise If your not comforatble pulling your notebook apart I'd get a professional to fix it.
Posted on Oct 21, 2008
Eratic mouse
Try cleaning the optical emitter and reflector of the mouse with alcohol.
Try disabling your touch pad and or touch screen. (Device Mgr.)
Check your mouse setting in Control panel (Uncheck the box next to "Enhance pointer precision"),
Calibrate your monitor
Aug 21, 2016 | Computers & Internet
Sony vaio PCG-391M touch pad freezing
If you have a Sony Notebook Setup utility under Start Menu, All Programs, Vaio folder, it can have a Touchpad tab where you can disable the touchpad.
Dec 14, 2013 | Computers & Internet
Acer Aspire M/ The cursor disappeared and I cant get it back
first confirm that your touch pad is working or not. yor touch pad may be disabled or it may be dead. you can enable your touch pad in it's setting. you can connect an external mouse to your laptop to check that. or you can enable mouse keys in control panel.
Apr 10, 2013 | Acer Aspire Computers & Internet
I have a Dell Inspiron 1545 which has three problems, the battery discharges faster than when used by another computer of the same make, the screen lighting often blinks severally before it completely goes...
run crude cleaner to get the flicker and speed the laptop up
get a new battery... if discharges too fast.. like less than 45 minutes
cursor jumping around.. watch your touchpad..
commonly you are touching the mouse pad during some keystrokes
you can set the mouse pad sensitivity downward under control panel--> mouse---> synaptics mouse pad sensitivity also
Jan 21, 2011 | Computers & Internet
Slow pc cursor gets out of control
Hmmm... There are 2 things when the cursor goes wild, either ur mouse have a problem(dirty roller balls, open ur roller ball and clean the dirt in the wheel. And for the optic type the lens have to be clean and use a BLACK mouse pad). The other one would be ur processor is getting HOT, heat sink needs to be clean and remove DUST particles in the heat sink!
Hope that helps u out!
Nov 20, 2010 | Symantec Norton Antivirus 2010 Full...
Cursor on Laptop goes WILD while typing
Go to Control Panel, Mouse, click on Pointer Options tab and uncheck Hide Pointer while typing. This fixed it for me.
Apr 19, 2010 | Toshiba Satellite A100-S8111TD Notebook
Cursor will not move on screen when using touch pad i've shut the computer down and restarted but cant get the cursor to move
Please press Fn+F9 key to ensure the mouse pad isn't disabled. The key should have these symbols on it.
Hope this helps,
Jan 30, 2010 | Toshiba Satellite Pro P300 Notebook
Cursor jumps around when I touch the mouse pad/
Maybe try updating the drivers for the touchpad or adjusting the settings in the control panel.
You can update drivers for the touchpad in the device manager.
Oct 16, 2009 | Toshiba Portege 2000 Notebook
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Acer Vista Laptop and cursor nightmare!!
Hi -
I've been having the same problem and it is MAJORLY annoying to be typing along, and have the cursor reappear on another line!
I had a heck of a time finding the place to disable the touchpad, since we use a USB mouse with the laptop. Turns out, someone else helped me find a simple way - hold down the Fn key (next to the left side CNTRL key), and hit F7. That toggles the touchpad off/on easily!
Also suggested by someone else, some mice can cause erratice behavior with Acer laptops, so perhaps try another mouse?
So far, I've been typing this response AFTER disabling the touchpad, and the cursor has not jumped around at all.
Good luck! : )
Dec 10, 2007 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
