Question about LG Electronics GSA-H42LK LightScribe 18X Double Layer DVD+/-RW Internal Drive (Black) - Bulk [GSA-... Burner
I just bought a DualBrite Motion Sensing Diecast Latern. The lights stays on instead going off and coming back on when there is motion.
I want my motion securtiy light to acturally stay on all night. more after animals than people, can this be done?
Usually with mains power motion lights if you switch them on and off two or three times and then back to on, the light will stay on all the time. To put it back to motion, switch off, wait a minute and then switch to on.
This is borne out by this article
Search Results Most motion detectors have a built-in override:
  1. Normally the switch is kept on all the time. ...
  2. If you turn the switch off and on within a second or so, the light will stay on, and this overrides motion detection.
  3. To go back to normal operation, turn the switch off and wait ~10 seconds, then turn back on.
More items...
lighting - How can I override a motion detector light? - Home ...
https://diy.stackexchange.com/questions/.../how-can-i-override-a-motion-detector-light
make motion security light stay on Google Search
Sep 04, 2017 | Home Security
Why when washing hands, faucet keeps shutting off.
Motion sensing technology is a great feature but has some limitations. The motion sensing is limited for one main reason if it senses motion to far away from the faucet the faucet would come on when you walk by so the motion sensor is very restrictive in it's distance and angle of sensing. When you first start washing your hands you probably bring them in close to start the faucet but then lower them or bring them further away from the faucet. This in turn takes your movement away from the sensing eye and the sensor stops sensing movement and shuts the faucet off. Try finding out what distances the sensors movement to see where it stops recognizing that there is someone using the faucet. this will give you an idea of where you have to stay when using the faucet to keep it sensing correctly. I know this seems like a loto f work to use something so intelligent but in fact the faucet is very dump and has a limited function pattern.
One thing to also check if the faucet was working fine but then just started to malfunction is that the sensing eye is not dirty, covered in mineral deposits or the lens is not scratch badly. All the above problems can cause the sensor to miss read motion or have trouble sensing motion. Since this is a moen they are usually very good about replacement parts.
Jun 10, 2014 | Moen One Handle High Arc Pulldown Kitchen...
Lights flash on and off
Very common issue with motion sensing lights. You can either replace the light sensor which is available at most hardware stores or you can disable the motion sensing feature and just have an on-off light. To disable the sensor, (turn off the power!) unscrew and remove the light sensor (it is the reposition-able box under the light.) It depends on the particular light, but you usually just match up the wire coming into the light from the house and the wire from the bulbs and connect them with a wire-nut.
Jan 07, 2014 | Heath Zenith SL-5318-WH Dual Brite Motion...
Motion sensor outdoor light won't go off
How long has this been going on? Has this light fixture been updated recently? Has the lite switch been changed that operates this fixture?
Feb 23, 2013 | Cooper Lighting regent light BRZ Motion...
Motion light stays on
If there is a "sensitivity" setting, it appears to be sett too sensitive, therefore the unit thinks there is constant motion.
Cannot get light to go on and then off at programmed time. Stays on. At cottage with no neighbours or ambient light. Installed professionally, not by myself. Frustrated many efforts before contacting...
Light stays on all the time: Turn power to light off. Wait 10 seconds. Turn power back on.
Typical option on motion lights: Quick power flick -- light stays on. Slow power flick -- light goes into motion sensing mode.
Hopefully the professional installer gave you a switch.
Jun 01, 2011 | Heath Zenith SL-5318-WH Dual Brite Motion...
I bought two motion sensing diecast lanterns model HB-4190 series, SKU 248-593 and the instructions are hard to understand. To make it easy tell me how to set the device if I want it to come on only if...
Hello Gerald. Each switch has a function. the the test-1-5-10 allows you to set it to test or an on period of 1 or 5 or 10 minutes. The off-3-6-dusk to dawn allows you to turn it off completely, operate from dusk for 3 hours, operate from dusk for 6 hours or operate from dusk to dawn. By operate I mean turn on and then stay on for the number of minutes you set it to with the other switch.
what's nice about the test setting is that with it allows you to check and b sure that the light will come on during daylight by setting the one switch to test and the otner to any setting but off.
If you leave the 2nd switch set to off the first switch will not allow you to test it.
Joe
May 22, 2011 | Garden
My journeyman motion light just quit working for no reason. The bubls are good. As mention it was working fine then just stop working. What could be the problem?
The motion sensor unit shorted to due to rainwater infiltration, if its like the last half-dozen motion sensor units I opened up. Take the unit down, open up the sensor unit head, and if its got moisture inside, you know why it quit. If not moisture, then they sometimes do what all electronic devices eventually do, they fail due to 1 of the components reaching its failure - every sensor has an MTBF
(mean time between failure).
Jan 05, 2011 | Heath Zenith Journeyman 270 Degree Motion...
Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
LG Electronics GSA-H42LK LightScribe 18X Double Layer DVD+/-RW Internal Drive (Black) - Bulk [GSA-... Burner Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
