Question about Emerson EWF2703 27" TV
Chset stuck on our old emerson TV chset and channel number is stuck on TV how do i turn it off
  • Vera Fotheringhame Jul 14, 2006
    we are using an all for one remote as the original gave up many years ago?
  • littles4 Feb 04, 2009
    i have the same problem! no matter what remote i buy, i can't get the "03" off the top right portion of the screen!!
    New Friend:
You can also press "info", especially on A Comcast remote that is programmed to the tv and it'll come right off.
Posted on Dec 02, 2013
  • 1,476 Answers
You should have a button on your remote which says "display". Pushing that should toggle the ch number off. Hope this helps.
Posted on Jul 12, 2006
My Emerson TV is stuck on number 1 channel how do I get it to go to other channels?
Need to go into the menu look for the channel setup then check the skipped channels make sure channel 1 isn't the only Channel not checked also Look at Your scanned channels in the channel list how many do you have is channel 1 it ? you may need to rescan your channels . If the TV worked OK before but Not now try resetting Your TV , BUT do this last as You will need to reset all the parameters in Your initial setup as well as rescanning channels also the Volume may blast you after reset I always install a set of earphones in the Audio phone jack first . To reset the TV Unplug it from the back of the set wait 30-40 seconds reconnect the plug while holding the Power Button Reset Your Options and Settings then Rescan your channels Don't forget the volume and to unplug earphones Good Luck
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
May 18, 2016 | Emerson Televison & Video
Model ewt1321 emerson tv stuck on channel22 so direct tv will not work snow only
with the set turned off --unplug it for a few minutes and plug back in which may allow it to reset itself
Mar 23, 2012 | Emerson SpongeBob SquarePants TV
It stays on for 15-20 seconds then turns off
the tv is shorting out. means its probably old and needs to be replaced. if its not very old its just got a faulty part. get ahold of manufacturer emerson technical service and they will tell you your options.
http://www.emersonaudiovideo.com/support/contact.php
If your items are one of following model numbers;
19 LC8 EMERSON LC190EM1
22 LC8 EMERSON LC220EM1
26 LC8 EMERSON LC260EM1
32 LC8 EMERSON LC320EM1
40 LC8 EMERSON LC407EM1
19 LC7.5 EMERSON LD190EM1
32 LC7.5 EMERSON LD320EM1
Please call 866-309-8819
Operation hours: (Mon-Sat 8am - 11pm EST, Sun 9am - 6pm EST)
*Above model numbers with the "R" in front also call 866-309-8819
Example: RLC190EM1 or RLC220EM1
All other model numbers
Please call 800-256-2487
Operation hours: (Mon-Sun 6am - 8pm PST)
-Derek
Jan 11, 2011 | Emerson EWC13D4 13 in. TV/DVD Combo
I have a EWC19T3 tv/vcr/dvd combo my ex-boyfriend threw the remote and shattered it. I have a philips/magnavox universal remote but I've tried all the codes listed for emerson (which is a lot) and none of...
Unfortunately, the remote you picked up may be incompatible with your current TV. (I found older universal remotes didn't work with my newest set that had a digital tuner. These were remotes that worked with ~20 year old tvs (analog only). Similarly a new remote might not work with an older TV. Then you get stuck with the result you have.)
Remotes.com has a substitute remote that has all of the functions of the original remote: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=EWC19T3&uuid=12792355576670
This one will work.
Your TV has Select, volume and channel change buttons on the front of the TV. So a tedious way to deal with the problem is to move to the TV to change channels. The Volume controls are under the DVD tray. Select (toggle TV/VCR, DVD, and external input) is the first one on the left under the VCR cassette slot. The channel up/down is to the right of the Select.
I wish that I could be of more help.
(However, you might try the Philips Remote Code Finder: http://www.urc.philips.com/ and select your country and click on the right arrow. Then find your remote model and see if you can get a single number for your TV. On the newer remotes I looked at, it only returned a code of 0917 for All Emerson devices.)
Jul 14, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
CODE FOR A REMOTE CONTROL
I am not sure of the model remote but, on the newer TW remotes you would press tv then press and hold set up until the tv light blinks twice. then enter 991 on the number pad and then press power once. then press the channel up button until the tv turns off. as soon as it turns off - press the power button and if it turns on then you have the right code. If it doesn't turn on then press channel down until it turns on. either way, when the tv turns on then press set up again to lock that code in. Hope that helps.
Feb 10, 2009 | Emerson Televison & Video
Emerson VCR/DVD player - can't get tv (cable tv) to play anymore
I have the same problem with my Emerson VCR. When the ADD button is flashing, just press the menu button to exit the menu. It will add. That's the only thing I know to do. Sometimes it works, sometimes it doesn't.
Feb 01, 2009 | Emerson EWD2203 DVD Player/VCR
Looking for a remote for an old Emerson TV
Call 1 800 Remotes or go to www.remotes.com. In the middle of the page type in the model number which in your case would be VT1920. I believe the original remote is not available anymore but you can get a substitute remote for that TV. Also have you considered getting a universal remote? Those work on any TV with any component. Try the first two suggestions and hopefully you will find what you are looking for...
Hope this helps,
Sincerely,
Raelyn
Jan 06, 2009 | Emerson EWF2703 27" TV
Emerson tv stuck in video mode
Done - channel scan put the TV back in the correct mode
Nov 18, 2008 | Emerson EWF2004 20" TV
Tv stuck on video
Try with the channel up/down on the TV or look inside the configuration menu, if your set has one.
Feb 15, 2008 | Emerson EWF2004 20" TV
Emerson EWF2703 27" TV Logo
234 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
