Question about Panasonic PV-M2048 20 in. Combo
My TV Says Line and Displays Just One Channel
Hi my tv says "line" and the screen is black, but when i try to use the channel buttons to move up or down, it Oscillates Between Channel 41 and LINE. i have also tried to hook up my cable with to the tv and nothing happens. i don't see a button where i can adjust the set up (on the actual tv as i don't have a remote) what should i do to make the tv work again (or to get into the set up options to try to fix it?)The VCR and the FM Works Fine.Without a Remote has the TV bcome Useless?Also If I use any other Remote can I acheive what I could from this TV's Particular Remote. Thanks Robin
    President:
  • 3,130 Answers
Unfortanatly, your gonna need the original remote or a simular one to get to the channel programming mode in the menu. You can go to http://remotes.com or call 1-800-remotes and get one for your set. Im sorry i couldnt assist you more. Good Luck
Posted on Jul 12, 2006
Hi I have a THORN hd smart tv 55' turns on but then just black screen sound is fine can change the channel but can't see a thing tried unplugging it holding power button down for 60 sec
I have a 55inch thorn TV not a smart TV Tho n it keeps randomly turning off day and night n once it flicked from hdmi channel to normal TV channel, no set some or anything I'm worried a fault or boogidy, it's bout 5 or 6 years old n only been doing it the last week ??
Mar 31, 2017 | Televison & Video
I pressed a button by mistake and my Sony tv has no picture. Now has small box left hand upper corner with A and lines like wifi icon
Try the RETURN button on the remote to get back to viewing.
Get the manual at Sony KDL 40S2010 Manuals See page 11 for remote control keys and page 38 for further trouble shooting if necessary
Jun 03, 2016 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Black screen horizontal white line moving from top to bottom of screen
Hi Mandy
Think you have a problem with the cabel or if you could adjust the channel for the correct signal. Maybe the tv-chip on the consol are broken, and you live to far from me for me to help :)
you have any friend who could take a look ?
Best regards
Joakim
Feb 26, 2013 | Atari 2600 Console
Sharp tv #27sc26d no picture have sound
There is a voltage loss in the main board. It will be best to contact any experienced service technician, as the work is a skilled one.
Jan 03, 2013 | Sharp 27SC26B 27" TV
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
Black screen ecept for thin white line around all four side. Channel buton changes colors in various section of screen. On/ off button does not work
I found the solution on mine. To restate, I just saw a thin white border around a black screen. Pressing the channel up or down buttons changed the screen, in some kind of test mode to shades of gray, and red, green, and blue. I started finding a solution when I noticed when on one of the color screens, that the volume up or down buttons brought up a new menu for color intensity. Finally, I got back to the thin white border screen and pressed the arrow keys in the top half of the remote. Finally a TV screen and I pressed the enter key! Voila!
Mar 14, 2010 | Sylvania LC320SLX 32 in. LCD TV
Ilo tv shows no tv signal, I believe that the channels are deleted but don't know how to add the channels back
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Jan 08, 2010 | iLO IWT3206 TV
Thick Black Line Down Middle of TV
does this only occur with one input and/or does it occur when using HDMI/component cables.
if so, try getting a new HDMI cable. I have the same problem with PS3...and im about to order a new HDMI cable.
Sep 30, 2008 | Panasonic PT-52LCX65 44" HDTV
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
Panasonic PV-M2048 20 in. Combo Logo
226 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
