Question about Garden
Chainsaw well not stay running
Chainsaw starts up, then idles all crazy up then down.Then it dies. I think the high and low settings are way off. I also would like two know the factory settings for this model. Have any ideas?
  • 1 more comment
  • dmblank7 Dec 08, 2008
    How do you adjust the low speed and high speed adjustments on carbureator. I have taken cover off and can't see any way to make the adjustment.
  • Anonymous Dec 30, 2008
    Its not the GAsket, Its the Settings, I thought the Throttle was stuck, but its not, It wont idol, it just Runs full speed or dies....
  • erieangler Feb 14, 2009
    how do i unclog the brake or clutch on poulan model 2075c
    Sergeant:
  • 314 Answers
Start with a new sparkplug, then check the gasket on the carb. The bolts that hold the carb on should be tightened equally. If it is a very old saw the crank seals could be the prob too! Hope not! Frankster016
Posted on Oct 21, 2008
Chainsaw wont stay running
if it starts (maybe idles) but then dies when giving it gas it sure looks like its a carb problem , most likely dirt in the high speed jet , but could be a dirty fuel filter as well and that's inside the fuel tank
Apr 16, 2015 | Stihl Garden
How to set the high and low
Turn mixture screws completely in gently, then wind out 11/2 turns each. The saw will be able to start and run at this point. On idle wind Low clockwise till motor starts to die then anti-clockwise 3/4 turn.
High speed is a little more difficult, On full revs wind clockwise till saw starts to rev out (lean Mixture) then back till the sound starts to bubble.
Jul 26, 2014 | Husqvarna Garden
After the chainsaw starts up it will idle the min. you disengauge the high idle on the choke it runs for about 3 seconds and then dies like it ran out of gas
When it dies pull out the spark plug. If it is dry it is getting not enough fuel,wet is too much .Adjust the L needle till it stays running.
Jan 26, 2014 | Poulan Garden
Poulan chainsaw, I rebuilt the carb with all new everything. Now it will start with choke all the way out. Idles really high. If I push choke in, it dies instantly. The hi-lo and Idle is off I know for...
get it running on idle,adjust the idle down till it runs hairy,then adjust low speed mixture screw till you get it highest revs,then keep repeating that till you get it idling normal.rev saw up max revs,adjust high speed jet, in or out till you get max revs,then screw out one quater of a turn.That lets enough fuel thru to cool the sparkplug tip..If thats no good,redo the carbi.Check the tiny filter under the needlevalve hole.Check the needlevalve diaphragm height.recheck gaskets are right way round
Nov 03, 2013 | Husqvarna Chain Saw 20" Bar
My e series 142 spins the chain and idles insanely fast when I have the choke pulled out. Then when I give it throttle it calms down and then I can barely keep it idling. with throttle all the way pulled...
Check air filter- clean or replace, Make sure you have fresh fuel, A new spark while you are giving it a service, Do you know how to tune the saw? Start with basic settings 1 turn on the low and 1 turn on the high And adjust from there, You might have turned the idle up too high. The choke should always be fully in when saw is running. Hope this is a good start
Oct 04, 2013 | Husqvarna Garden
Wont stay running. it idles kinda high. stays running with the choke on. pull the trigger 2 giv it gas it dies.
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. The idle speed screw (turned CCW) will slow the engine down. Hope this helps!
Nov 08, 2010 | Poulan Pro Chain Saw 46cc 20"
Need intructions on carberator adjustments for mac-3514 35cc/cm3 runs but hard to start after using it for few minutes.
There is a low speed jet and high speed. Low speed sets the idle or stays running without feathering the throttle./// When setting high speed, hold the throttle wide open until engine revs high, then turn back in(at least ¼ turn) to slow the engine which in turn gives the engine more gas and runs cooler. If you have it too lean on the high speed, it will be hot and hard to start. Sometimes using 40 to 1 mix helps with starting, especially on older chainsaw. good luck
Sep 22, 2010 | McCulloch Garden
Homelite chainsaw won't stay running
Make sure you are using fresh fuel mix (50:1 ratio). Don't use boat motor oil in a saw--only modern synthetics made for saws. Always premix the oil and fuel thoroughly before adding to the saw. Check the fuel filter for plugging and the condition of all fuel lines, plus the primer bulb condition. Check all carburetor fasteners for tightness. Make sure the air filter and muffler are not plugged. If still no help, you may need to service the carburetor. For an excellent article on Walbro carburetors, go to: http://www.drystacked.com Pay particular attention to the placement of the lower diaphragm and the cover gasket--interchanging positions of them cause many headaches. Adjustment of the two jet screws require a special 'D' screwdriver which may necessitate a trip to a servicing dealer for adjustment. Hope this helps!
May 04, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Need carb h/l ajustemts and idle controle ajustment
This does take a little time to get it just right. Start at one full turn for the h and l. Work on the high first and after you get the H running work on the Low. They have to work together. So if you get it to idle and run at full throttle but it hesitates when you pull the trigger just adjust the low a little higher.
May 02, 2009 | Poulan Pro Chain Saw 46cc 20"
Need carberator settings for a sears craftsman chainsaw model#358.354831
You don't want to tighten them down just turn them in until the are just snug and then turn them out.
Start with the low at 2 full turns out and the high at about 1 full turn out. Start the saw and let it idle adjust the low idle to where it runs smooth. Adjust the high until the saw runs as much rpm as you can get at w.o.t. (Wide Open Throttle).
Jul 11, 2008 | Electrical Supplies
Garden Logo
590 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
