Question about Sony DSR-30 Mini DV VCR
Bad Audio Circuit board
Hello. I had a circuit board go bad in my DSR-30, and it is effecting all audio coming out of the deck. This machine has not been abused, and could last a few more years if I fix it, but the repair shop I sent it to sent it off to Sony, and I got a quote of over $2,000 to replace the board. Does that sound reasonable (I don't know how much the middle men are marking this up)? Is there anybody out there who knows a place that can help me without killing me on the cost?
Brett
  • bpkjets Oct 22, 2008
    Thank you very much, I'll go there right now...
    Genius:
  • 2,035 Answers
If you want to check the similar player for $500 on ebay :Please click on this link:You can use this player unit on your player....
http://cgi.ebay.com/Sony-DSR-30-Digital-Video-Cassette-Recorder_W0QQitemZ220296799578QQcmdZViewItem
Good luck......
Posted on Oct 21, 2008
    Brigadier General:
  • 6,966 Answers
The DSR-30 being a digital video cassette recorder with editing features is a rather complicated equipment and requires critical alignment, Having said this, then the repairs not only involves simple parts or board replacement but studio quality calibrations. This what makes the repair cost rather expensive.
Alternative options would be:
  • component level repair.
  • source out defective DSR-30s and make use of their boards.
Both of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Sony Master
  • 6,487 Answers
Since the device will be sent to Sony for repair definitely the cost will be higher as expected, but if you like you can check this link and contact them and ask how much will its cost for the repair for this unit I bet it will be much cheaper http://www.cwservice.com/sony.htm
Tascam 238 recording deck will not stop rewinding.
Are you any good at surface mount circuit board repair? It seems that the caps go bad. Check out this: http://www.thegreatbear.net/audio-transfer/8-track-cassette-capstan-motor-tascam-238-syncaset/
Jun 08, 2014 | Tascam 2488 Portastudio Multitrack...
Why does my sony gx450 cuts out when the speakers come on?
You probably have bad solder connections on the printed circuit board, check the speaker wires on the back for possible shorts. If the tuner is additional problem it is much more difficult to repair and would require a service manual with the proper test equipment.
Jul 01, 2012 | Sony 560W 5-Disc Mini Hi-Fi Stereo System...
My DSR 45 Firewire port is fried. Any idea which Problem with the Sony DSR-45 Mini DV VCR
DSR-45's firewire port is held on a separate littlle circuit board, easily reached from the underside of the deck. Remove the bottom panel, unplug the cable from the Firewire board and there is 1 screw to hold the firewire board in place. The part is called DV-032 on Sony's Parts website and costs about £30 UK including postage to buy.
Sep 16, 2011 | Sony DSR-45 Mini DV VCR
I have lost sound in the left earcup of my Bose QC3 headphones, although sound comes from the right earcup. How should I proceed to fix it?
The solution to this problem is not for the faint hearted. You will break your headset, you will void your warranty, and you quite likely will end up with a non-working headset. You will also have to solder very small electrical components.
I also had the left channel audio not working, so the first thing to do was to take apart the headset.
Step 1. Remove the battery. Remove the two tiny screws from under the u-shaped plastic piece that holds the earpiece to the headset. You will have to pop out the end furthest from the audio jack. A #0 phillips is needed. Put the tiny screws in a safe place.
Step 2, Break the silver cover free from the black plastic earpiece by sliding a flat blade screw driver down between the joint towards the bottom of the earpiece. Be very careful not to insert the screwdriver blade too far into the earpiece because the circuit board is just inside. For some reason Bose decided to glue the two attachments for the bottom of the silver cover to the earpiece.
Step 3. Unscrew the 3 screws holding down the circuit board and put them in a safe place. Gently pull up the circuit board about .5cm. Look at the audio jack, the tab on the circuit board on the bottom right is the left channel audio. You can try to reflow the solder at this point on that tab using a 25W iron. It didn't work for me, but if your connector is not as bad a mine, it might work.
Step 4. Remove the solder from the 4 tabs holding the audio jack to the circuit board. Remove the audio jack from the circuit board (this is hard and accompanied by much cursing). Try not to overheat the board and lift the lands. Use a pliers to pull out the contact for the left audio channel and bend the jack contact out 1mm or so. Insert it back into the audio jack. Get your audio cord, plug it into the jack and check and see if you have continuity with an ohmmeter. If it all checks out, continue on.
Step 5. Resolder the audio jack back into the circuit board (also accompanied by much cursing). Screw the circuit board down. Put the battery back in and see if everything still works. If it doesn't, check to see if you broke the fine wires just above the audio jack on the circuit board. They run to the other earpiece through the headset.
Step 6. Reassemble everything and see if it still works. If it does, then congratulations and enjoy your restored audio. If not, open it back up and look for broken wires.
Disclaimer: This solution will likely destroy your headset. Proceed only if you have experience working with modern surface mount parts. I am an electrical engineer with 30 years experience in troubleshooting and repairing electronics and it still was not an easy fix. Total time to repair was about 4 hours.
Dec 13, 2010 | Bose QuietComfort 3 Acoustic Noise...
My fuse blew in my car so i replaced the fuse. but now the deck says 'protect' now what?
Hello sir, the reason why the fuse blows up is a short circuit problem or overload on the stereo, unless the short can be find and replace the message will stay, I suspect the power amplifier IC is the bad part. have the unit checked by your dealer or an audio shop to solve the problem. Most likely those audio shop will have ideas of the problem.
Dec 11, 2010 | JVC HX-D7 DVD Compact Stereo Audio / Video...
DSR-1500 firewire port doesn't work. Any
It may be that the firewire cable has been inserted the wrong way round. Unfortunately this is a common problem as it is quite easy to do this especially when fumbling around with limited access behind the deck. Worst case scenario is that the Firewire circuit board has been fried! Firewire connection carries 30 volts, and if this connect to the wrong pins - pop goes the board. It's a £300 job to fix (I think). But first of all try pairing down any patching / connection to other equipement to a minimum to ensure that there is not something else in the chain that could be causing the problem.
Oct 06, 2009 | Sony DSR-1500 Mini DV VCR
Buzzing sound through the speakers effecting all input components
hello
The buzzing sound that you have mentioned may be due to following reasons.
  • The power supply may be internally producing spark or power lines are damaged.
  • There may be some connector which is not connected properly. Check the connectors which connect the speakers to the audio system.
  • Any of the connector may be damaged. Again check the connectors.
  • Check your power supply.There may be some sparking or adapter not connected properly.
  • If these are not your solution then your connectors are damaged internally.
Hope this will solve your problem.
Thank you
Aug 15, 2009 | Sherwood Audio Players & Recorders
No sound on tv switch positon. works on dvd
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
Feb 28, 2009 | Televison & Video
DSR-11 stopped outputting anything
I have almost the same problem!  Did you ever figure out what happened?  Here's what I had posted yesterday:
Tech Friends -
I recently got a non-sony tape stuck in my DSR-11 (bummer) and was forced to extricate it using the "my tape got stuck in the DSR - 11" article's method of removing the top cover and highest level of circuit board:
http://www.fixya.com/support/t178954-tape_stuck_inside
This worked for the tape removal, however, upon replacing the circuit board and cover, the deck no longer seems to be able to do anything with video or audio.  It still communicates with FCP via its firewire connection (ie FCP is able to control FF, rewind, play functions, etc), but it seems unable to read or write video.  Also, we use it as an A - D converter box between a Beta SP deck and thecomputer (actually, this is the deck's main function here).  Even when I switch it to the correct setting (video) and check to make sure that everything is plugged in correctly (trust me, I checked, it is), I get the "there is no video here" error message.
Also, after trouble shooting the drive for a little while, I pressed the "reset" button the the rear.  I'm not sure if that matters one way or the other.  I don't think it does (that just resets the time code, right?)
The question is, would this be a case of "fried firewire jack" such as it seems so many of us DSR - 11 owners have?  Could I have done any frying myself by not having myself properly grounded when opening the shell?  Is there anyone who knows the answer?  Help!  I can't digitize my video!
Comment by eltriunfo, posted on Sep 05, 2008 The Plot Thickens...
Okay, I've checked all of the FCP settings and played with the deck more and it's only confused me more.  I can now get it to not only be controlled by the computer, but actually print audio and video to mini dv tape.  Also, I can record from my Beta SP deck to miniDV tape in the deck (connected through the "video" input on the rear of the unit).  In other words, the deck seems to function perfectly doing everything except for converting analogue to digital passively.  The way we always did it before was by keeping the input switch on the face of the unit on "video" and log and capturing in FCP with it as a noncontrolable ntsc device.  This makes me understand it less.  It means to me that it is not a broken switch, it's not a broken firewire port, everything works perfectly EXCEPT for using the unit as an A-D converter.  What the dill-yo?  If anyone in the world could offer any insight as to what could be causing this I would greatly appreciate it!
Jun 19, 2008 | Sony DSR-11 DV / Mini DV VCR
1210 mk5g pitch adjustor
switch off for a will and see.
if still bad. check the circuit board under.
with old electronic devices, capacitors are commly the ones that may go wrong/dry. which would cause oscillatory circuit to generate wrong signals or strobe or feebacks. if you know how to take out the circuit board, check it starting from capacitors.
Jan 22, 2008 | Technics SL-1210M5G Turntable
Sony DSR-30 Mini DV VCR Logo
175 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
