Question about Sony Handycam CCD-TRV308 Camcorder
No playback We can see the image in fast forward or rewind but only a blue screen in playback mode. No sound either
    Scholar:
  • 107 Answers
It could be video head partial damaged or got dusty, another possibility the tape guide alignment was out of position. If the video defective it require to replace1 drum assembly it come the video head and motor it is not worth to repair and you need a qualifier Tech after replace it they need to connect computer to do alignment mechanism and electronics
If the head is dusty you could try insert the H8 tape cleaning should buy from Sony may be you can clean the video head the change is 30% success
I hope that give you some ideas
Posted on Dec 04, 2008
I am trying to find out what the blue symbols on the function keys of my sk 9020 keyboard stand for
The blue keys serve as a secondary function for your volume control, monitor controls and pause play fast forward rewind (in media mode). In order to use the blue keys that are numbered from F1 to F12, you must depress and hold the Fn key that is located at the bottom left side of the keyboard. Here is a way to test it: Open up any file that plays sound for longer than 1 minute (60 seconds). While this file is playing, hold down the Fn key and simultaneously press F8 and listen to the volume get louder or Fn and F7 together and listen to the sound get lower. The picture of the crescent moon F1 will adjust the brightness of your screen. F2 will magnify your screen. F3 will take you to your email. F4 will take you to your internet home page. F6 will mute the volume. F7 will lower the volume. F8 will raise the volume. F9 will rewind your video playing. F10 will stop the video. F11 will pause or play the video. F12 will fast forward the video.
Mar 06, 2012 | Gateway (7001434) Keyboard
Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Aug 18, 2007 | Sony Handycam CCD-TRV37 Camcorder
Playback
when I plug in the RPU DC cord from my camera to the input on my tv I get nothing. Is my input jack bad or what. Also, if I tried the s video jack from the camera to the tv, would that work??? I don't know what the AV out jack is for I don't have a cord for that
Nov 12, 2008 | Sony Handycam CCD-TRV308 Camcorder
No playback
Even though my husband cleaned the head with a q-tip and alcohol, I decided to purchase a cleaning tape. I popped it in and it worked in less than 15 seconds! It was expensive, $18, but not nearly expensive as a new camera!
Jun 23, 2008 | Panasonic PV-GS2 Mini DV Digital Camcorder
Sony Handycam CCD-TRV87 Hi-8...
I am having the same problem. When I hit Rewind or Fast Foward, i can see the image moving clearly.
When I hit play though, I just get a BLUE screen with the Play arrow displayed. So it's playing, I just got a blue screen. And last night, I got the blue screen but I could hear the audio.
Then I put a head cleaning tape in the camera, and I did get the picture back on for a little bit.
Skip to this morning, and we are back to the Blue screen again. Only this time, I am getting no audio. And I the head cleaning tape back in but it's not helping anymore.
Jun 10, 2008 | Sony Handycam CCD-TRV87 Camcorder
When we Fast Forward or Rewind the screen turns blue
try to not fast foward and see what happens
Apr 15, 2008 | Televison & Video
No Picture on playback
alignment is offset, should be easy fix with you local electronics repair place....if you need a cost estimate let me know model
Jan 20, 2008 | Video Cameras
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
Sony Handycam CCD-TRV308 Camcorder Logo
142 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
