Question about Panasonic CT-27HL14 27" TV
TV does not turn on
TV stopped working, now it has no video or audio & the power LED flashes red every few seconds.
  • 1,476 Answers
You have a short in your unit somewhere or a high voltage problem. The most common problem would be a high voltage failure. If you are not familiar with televisions and their safety this is best left to a repair shop. There is not much in a TV that consumers, unfamiliar with the system, can check. The problem should not cost too much to fix. Check for a shop which has a free estimate or low estimate which will be subtracted from the cost of the repair if you choose to have the unit repaired there. Good luck.
Posted on Jul 12, 2006
LED tv has no picture and flashes on every few seconds
You have a bad panel (TV SCREEN). The LEDs are not coming on. You will have to replace all LEDS, and this can be very time consuming. The LEDs can be tough to find and buy. Many TV parts store are out of stock. Thanks for asking, Matt of Martins TV.
Jun 10, 2018 | LG Televison & Video
Five red blinks in Sony LED TV KDL 40W900A.
5 red flashes is a bad panel connection or internal panel short, very carefully take the panel connectors off and reseat them and see if that helps, unfortunately you may have a bad panel.
Oct 14, 2017 | Sony Televison & Video
Won't stay on
3-blinks by the SONY TV error code indicates that there is an audio circuit problem, ether is a shorted audio amp IC on the main board, or the power supply that supply the power to the audio amp section is defective.
May 22, 2017 | Sony KDL-52EX701 52 in. LED TV
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Power up Problem
my hitachi model number:55fx48b suddenly just stopped. I can unplug the tv, then turn it back on and red led light will come on for 2 seconds and shuts back off! Can you please help me
Jun 28, 2008 | Hitachi 55FX48B 55" Rear Projection...
Panasonic CT-27HL14 27" TV Logo
149 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
