Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Water not getting to ice maker
Kenmore 106.9555610 Mfg. 03/95 - we just got this from a relative who was not using the ice maker. We hooked it up and the water comes out the door, but it doesn't seem to go into the ice maker. Any suggestions?
  • Anonymous Oct 23, 2008
    water not getting to icemaker but working on the water supply
  • 120 Answers
Yes repl the water valve at the back of unit but first i need you to get an insulated wire strip the endes of it and remove front cover from ice maker lookt for th letter t and h insert the wire inside the holes and look at the ejector inside mold is it starts moving let it finish cycling it no water repl valve if it does not move repl module but is better or ice maker alomost same price
Posted on Oct 31, 2008
Ice maker in kenmore coldspot refrigerator quit making ice, nowater flow
There are several causes of no ice maker operation. First, is the freezer cold enough? It must be below 32F to operate the icemaker. 2nd: Is the bale or metal rod that runs along the side of the ice maker in the down position? 3rd: You may have a failed water solenoid valve, located on the back of the unit. The plastic or copper water line from your house's water supply is attached to this valve.
Apr 11, 2015 | Kenmore Refrigerators
Ice maker stopped filling with water
where the tube (water supply)cumes into the ice maker inside the freezer may be froze shut /locate it and see if it is use something small to open it up easy!
Apr 10, 2013 | Kenmore Refrigerators
My kenmore side by side is not making ice
when was the last time u change your water filter, if water is coming into the ice maker and it don,t make ice that means u have a defective ice maker, if no water comes into the ice maker check the water valve at the back of the refrigerator with an ohm meter for resistance if no resistance is present replace water valve,u should unplug water valve when checking
Jan 16, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore Coldspot (mfg date 10/00), model 106.70192001. The ice maker is NOT hooked up (by choice) and for the last several weeks, there has been water draining from freezer into fridge in a cyclic...
Your drain line is frozen and is not allowing the defrost water to drain to the pan below. You will need to remove the rear panel in the freezer and thaw the drain line. Make sure ALL ice is thawed before reassembling. I would recommend installing a drain heater so it will not happen again. They are inexpensive and easy to install. They come with complete instructions.
Mar 22, 2011 | Kenmore Refrigerators
I just got a new kenmore elite 28cube bottom freezer french door type. I have a reverse osmosis system feeding the ice maker and water despenser on door my water can fill a large glass in like 6 seconds...
NONE / unless the use of water is greater than the supply and what will hapen is the pressure will be to low to close the wate valve and a flood is possible . i used this system on my amana for years without any problems . it may not ever happen but it could . most mfg do not like this hook up . / hope this helped mm
Oct 22, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Hooked up water to frig and got water in door but no water to icemaker. Any ideas?
Make sure the lever is down on the ice maker . Also , can pour about 2/3 cup of water into ice maker , so it will freeze and start the cycle . Otherwise , wait , and when the ice maker gets cold enough , it will cycle on its on to start the ice making procedure . If you get water to the door , then it's connected properly , and water will go to the ice maker , if the water valve and ice maker are in working order .
Sep 09, 2009 | Kenmore Refrigerators
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Apr 08, 2009 | Kenmore Refrigerators
Refrigerator not making ice
Make sure the water line is clear and not kinked somewhere. It's also possible that the water line orifice is frozen inside the freezer at the ice maker area and blocking water flow. You can thaw it out with a hair dryer - point it at the water inlet - be careful
Mar 15, 2009 | Kenmore Refrigerators
Brand new Kenmore refrigerator, ice maker does not work
first off relax and give it time the ice maker need to cool to a certain temp before making any ice, 24 hours is a reccomnded minimum
Jan 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore ice maker
yes you need to hook up a line froun the cold water supply of the house to the water valve that is located at the back of the ref to the water valve that is down at the botton right corner
follow the water line from the top going into the icemaker down to the bottom there is where the valve is located behind the back cover
Apr 11, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
109 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
