Question about Tivoli Cherry Top-Firing Stereo Speaker - SS-0065-NA Computer Speakers
Tivoli Radio, I have this tivoli radio that work great at first, now it plays for a short time and power off. How do I fix the problem?
    New Friend:
  • 3 Answers
I have had the solder joints stress and fail to the power jack in both a Model Three and a Pal. Here are photos of a pretty simple repair if you can do light soldering.
Posted on Sep 17, 2013
  • 728 Answers
Does your radio have a sleep button or option? If so, check to make sure that you did not set it on accident or with out knowing. Or if it has batteries, check them to make sure they aren't dead or mixed with old or new.
Posted on Oct 22, 2008
Tivoli radio
An internal fuse may have opened or there could have been spontaneous power supply failure.
Dec 08, 2017 | Audio Players & Recorders
I Lost FM on my Tivoli Model One. While FM was playing I touched the radio and gave it a static shock (very dry climate) and lost the FM. AM and Aux are fine.
It will need to go to a service centre for repair. Most probably the static electric jolt will have taken out either the FM RF amplifier of the FM mixer, meaning it needs component level repairs :o(
Sep 20, 2013 | Tivoli Kloss Model One AM/FM Radio
Hello, my Tivoli radio was brought to Australia after an overseas trip to America. After adapting the plug I connected it to the power point. As I now know- the different (higher) voltage in Australia...
Hopefully this is just something simple like a blown fuse but here is a link to some recommendations on how to repair the radios
Jan 06, 2018 | Tivoli Kloss Model One AM/FM Radio
The radio will only turn on if the power supply is plugged in. Once it is on, it will run of battery for hours. It will no long turn on with just the battery. Tivoli suggested some type of amp issue. Have...
yes its possible <br /> the battery and the power supply have different connection on the main board, battery connector have a Diode that works like a valve when you connect the power supply it disconnect the battery <br /> I can fix this problem <br /> I am in NY - <a href=""></a>
Aug 20, 2010 | Tivoli PAL Radio
Tivoli model Satellite will not turn on. Had intermittant power issues. Moved the radio and it will no longer power on
The power control problem is easy to fix.
It can as simple as a fuse (I'm sure you check it already) or a switch that is piggy back on the volume control.
Radio Shack has a similar one HERE
Disconnect the AC outlet and open the main Tivoli unit.
Look at the back side of the volume switch and you will see a power switch piggy back onto the volume control.
You can bypass it or get the correct value Potentiometer + SPST switch.
Use an ohm meter to meter the both end of the potentiometer and if it's 10,000 ohm or 10k then just go to Radio Shack and ask for
10K-Ohm Audio Control Potentiometer with SPST Switch Model: 271-215 | Catalog #: 271-215
It's a direct replacement.
If the ohm read is other then 10K then you will need to order it for an electronic supply house.
Tivoli makes great radio.....if you want to sell it I want the first dip.
Jul 30, 2010 | Tivoli Henry Kloss Model Two FM/AM Radio
Tivoli Model One Radio Humming only, no reception
The fuse would cause a total absence of power. Your problem is likely a blown filter capacitor in the power supply. Unless you have electrical/electronic skills, the radio will require professional repair.
Oct 10, 2009 | Tivoli Kloss Model One AM/FM Radio
Tivoli model three clock problems
SELL! SELL! SELL! Yup the clock has bit the dust sell er and cut your losses.
May 12, 2009 | Tivoli Model Three Clock Radio
Antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Jan 06, 2009 | Tivoli (PAL) AM/FM Radio
Tivoli Cherry Top-Firing Stereo Speaker - SS-0065-NA Computer Speakers Logo
690 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
