Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Ukingston usb dt101P
CANNOT DETECTED BY COMPUTER
  • Zosimo Pato
    Zosimo Pato Oct 21, 2008
    it is already tested in other computer but no success
  • 95 Answers
Try it in another computer to start with.
Posted on Oct 21, 2008
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Have seagate free agent go window 7 not reconizing the unit. please help.
You can try to use a different usb port of your computer check if it will be detected or try to plugged a different usb device see if it will be detected by the computer.If you have a different computer try to check if it will be detected. If the computer detects a different device it only means that the hard drive that you are connecting to the computer is faulty.
Thanks for using Fixya.
Jan 27, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
USB flash drive is not detected by my computer.Please give me a solution.
Restart your computer, then try connecting to a different USB port on your computer.
Try connecting it to a different computer.
If it still is not detected, it is "dead". Spend $10 to $20 to buy a 2GB to 8GB replacement.
Nov 04, 2010 | Computers & Internet
Doesn't recognize the USB cable anymore. I have replacexd it twice and it won't let me install the printer.
There's a big chance here that the problem is not with the USB cable but with the USB port of your computer or with the printer itself, first that you can do here is to try connecting the printer on a different SUB port on your computer and check if it will be detected now by he computer but if still not better if you can try this printer to a different computer and check if it will be detected because if it will be detected on different computer so the problem is with the USB port of your computer.
In a point that the printer will still not be detected by different computer so the problem here is with the printer itself and the printer needs servicing already.
Feb 12, 2010 | Lexmark X5470 All-In-One InkJet Printer
I plug my camera into my computer and my computer won't find it .
If the camera is not detected by the computer what you can try here is to try connecting the camera on a different USB port and check if it will be detected , but if still not detected if possible for you to try a different USB cable that will be better or if possible also try to connect the camera on a different computer so we can isolate the problem if its just the USB cable , the USB port or the camera itself that is bad...
Jul 11, 2009 | Kodak EasyShare M863 Digital Camera
PLEOMAX 5GB Thumbdrive
Do you see a message on your system tray when it is plugged in? If you don't see any message, it means that the drive is not being detected. You can't retrieve any data or files on the thumb drive if it is not detected. Things you can try to isolate the problem:
1. Try a different USB port on your computer. Check if your thumb drive will be detected.
2. Try a different USB device like mouse on your USB port. If it is detected, it means that the problem is the thumb drive. If not, it means that the USB port is not working or is disabled.
3. Try the thumb drive on a different computer.
Hope this helps. ;-)
Oct 17, 2008 | Samsung Pleomax Zirex UHD-8G USB Hard...
Computer will not detect camera when connected via usb
First thing to do here is to try connecting the camera on a different USB port on the computer if its a tower connect the camera on the back USB port of it, if still not detected try connecting the camera on another computer and check if it will be detected , If still not detected the problem here can be with the USB cable that you're using so better try a different USB cable...
Hope that helps............
Sep 19, 2008 | Canon Cameras
WHY WONT MY BELKIN WIRELESS USB ADAPTER INSTALL ON MY COMPUTER IT SHOWS NOT DETECTED
it will install only if it get detected by the computer,
try diff USB port
try is on diff computer.
let me know what happen?
Aug 17, 2008 | Belkin Computers & Internet
When I plug in my Zen Micro to the PC to chage all i get is the flashing charge signal but the devices does not recgharge. This is the same USB that i have used successfully on another PC. it also wont...
I use to have that little player and i remember how it could be tricky on different computers.
from http://www.anythingbutipod.com/forum/showthread.php?t=27711
If these don't work please report back:
4. If the Zen is not detected by or charging from the computer when connected, make sure you are using a USB port on the back of the computer (built into the motherboard) instead of one wired to the case (front or side). That way you are using a USB port with the proper power output.
5. If the Zen is not detected by or charging from the computer when connected, make sure the USB port you are using are USB 2.0 and not v1.1. If you computer is a newer computer, this shouldn't be a problem, but if it is an older computer, it may only have USB 1.1 ports which doesn't output enough power as USB 2.0 ports.
6. If the Zen is not detected by or charging from the computer when connected, make sure you have no other USB devices plugged into the computer (front and back ports), but the Zen. That may be worth a try to see if you can get enough current from the USB ports to begin charging it again. Usually the more devices you have plugged into the USB ports, the less current that will be available for charging due to the power being shared with all other devices plugged in.
7. If the Zen is not detected by or charging from the computer when connected, make sure that the drivers are loading for it properly under Device Manager (no conflicts showing). I believe the Zen will not be detected or begin charging unless its drivers are loaded and working properly.
Jul 30, 2008 | Audio Players & Recorders
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
