I have a Coleman/Evcon Presidential ser# 074878. The plumber says the Heat exchanger is cracked. Is this something I can fix myself or is it less expenxive to buy a new furnace?
I would like to adjust flame for more heat. can you tell me the color of flame?
Posted on Dec 15, 2008
    Scholar:
  • 121 Answers
The heat exchanger is a bear to change. depending on the age of the unit it might be more practical to replace the unit. However unless you trust this service tech I'd get a second opinion, because it is rare that a heat exchanger will crack, plus by law he or she should have shut the furnace down do to carbonminoxde. Especially rare in Coleman Evcon series units.
Posted on Oct 21, 2008
  • Edward Boukater Oct 21, 2008
    If you send a complete serial number I may be able to tell you the age of the unit.
Coleman evcon furnace
Sounds like it isn't getting a call for heat. If you have a digital thermostat it could be the problem. I have seen them look like they are working but burn out. A simple way to check is take the stat off the wall. There is 2 wires. It's low voltage so don't worry about shock. Touch and hold them together. If it fires up change the t stat. On a . 2 wire it makes no difference which goes to W or R
Oct 16, 2013 | Heating & Cooling
Coleman evcon presidential
If it's a blower motor, then the contacts on the relay is welded shut and has to be manually opened.
Sep 30, 2013 | Coleman Heating & Cooling
ROLLOUT SWITCH OPEN, COLEMAN EVCON FURNACE
Reset the switch. Check the heat exchanger thoroughly for blockages, cracks or holes. Check induced draft motor for proper operation. Check flue pipe and chimney for obstructions.
Feb 18, 2013 | Rheem Heating & Cooling
Air conditioning runs all the time
I assume this is a manufactured home, this is probably a two transformer system, either your contactor is welded in the on positon or wyou have control wiring issues, (could be the thermostat)
Jul 12, 2009 | Coleman Heating & Cooling
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Coleman Evcon Furnace Model G8T10012UHB11A
you probably have a cracked heat exchanger which is causing the rollout switches to trip.even the tiniest of cracks will cause the fan to blow the flame back into the unit and cause them to trip. check the heat exchanger for even the tiniest of cracks if so replace it. and be sure to have a carbon monoxide alarm in your home.
Oct 25, 2008 | Heating & Cooling
The repairman said there was excessive rust and the area was pitted near the heat exchanger. The furnace is a Coleman EVCON Model BGD12520 about 11 years old. Could this be residue from the burner or...
if he said there is rusted heat exchanger he was right not to start the unit . you can only call for a second opinion and have a nother repairman confure the heat exchanger is beyond its life. and then ask if there is replacement exchanger avalable for your furnace if its not to old this may be a less expensive alternative.
hope this helps you
please post fead back
Oct 20, 2008 | Heating & Cooling
Heating & Cooling Logo
314 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
