Question about PC Chips M810DLU (M810DLUV75C) Motherboard
Bios Cpu could not find any driver update for my cpu amd mobile duron 4 1.4Ghz and the one i found is not sufficient? and also the exact bios wit a Rom file after flashing it without any problems but didn't Upgrade any changes to the Bios
    President:
  • 2,692 Answers
Here is the weblink for your model  to update BIOS and Driver. Confirm Version number. You could consider upgradeing  your CPU to one of a faster speed.
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=203&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=2
Posted on Feb 18, 2009
Amd 2600+ doesnt work
Check your bios version and make sure it is correct bios. You can check the Aopen site to download the new bios and flash utility to install it. Be carefull and make sure that it is CORRECT bios for EXACT Motherboard. The bios can be flashed wrong and leave you with a paper weight. Good Luck
Nov 22, 2009 | AOpen AK77-8XN Motherboard
Want to upgrade CPU and Ram on ASUS A7V-ML motherboard
Download a small utility called CPUID from http://www.cpuid.com or use this direct download link "http://www.cpuid.com/download/hwmonitorpro/HWMonitorPro_106.zip". Using this utility you can analyze your system hardware statistics and also you can find the RAM capacity supported in your system along with various other RAM parameters. It will also show you the available free RAM slots to use, as well. I hope this is useful to you.
Aug 04, 2009 | AMD Athlon , 650 MHz (-K7650) Processor...
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
Beeps beeps beeps everwhere on my desktop
Depends on the BIOS. The beep code means ether the memory or CPU. Since you are attempting to install a another CPU its probably a problem with the CPU itself (dameged or incompatible) or a BIOS setting problem. Also make sure you always use thermal paste. The replacement CPU might be heating up and not functioning.
May 26, 2009 | Asrock K7S8XE Motherboard
In what soft (utilites) I need for update BIOS votherboard ECS?
You don't need to update the BIOS unless something is not working, the BIOS tells the computer where to go to find the OS and then the OS takes over.
Soft Utilites means another word for 3rd Party software, so you download third party software to update your bios.
Mar 31, 2009 | EliteGroup ECS MB KT600-A VIAKT600 SocketA...
System freeze for a few second then back to normal
have you tried running benchmark software with both the 5600 and the 6000? if you run say aquamark or 3dmark 06 or 07 and compare the scores you will see which is faster then what... if the 5600 is in fact showing that its faster then you may have to update your bios so it recognizes the new cpu some mobos i have messed with had this problem but after flashing the bios it corrected the issue esp if the cpu was released say a year later from when the mobo was released. make sure you have amd driver software installed too this gives you a performance boost if you install the amd driver software rather then running windows drivers that automaticly installs on your computer when you install windows most forget about the drivers for the cpu because only recently amd started making drivers available directly from their sites. here is the link
http://www.amd.com/us-en/Processors/TechnicalResources/0,,30_182,00.html
make sure you download the model series you have in your computer
Jan 21, 2009 | Computers & Internet
Problems with m825g
STOP!! Don't do it!
The M825G uses the KM266 Pro and , if the BIOS is correct, auto detect the CPU and its speed. That BIOS has a built-in OC utility, and that is why the jumpers are disabled.
The odds are you have an incompatible core. Just because the CPU fits the socket, doesn't mean it can work with the MB/chipset.
Check this link for that MB just to make sure.
http://www.cpu-upgrade.com/mb-PC_CHIPS/M825G(v9.2a).html
May 21, 2008 | PC Chips M825G Motherboard
New processor and memory - how to configure SETUP???
you need to update (flash) your bios to recognize the new cpu. check with your motherboard's manufacturer for a bios update.
May 13, 2008 | MSI KT4 Ultra-SR Socket...
PC Chips M810DLU (M810DLUV75C) Motherboard Logo
93 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Sulkhan Abesadze
Sulkhan Abesadze
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
