Question about Sharp 56DR650 Television
Sharp TV Flashing Codes
We recently purchased a Sharp 56DR650 at a thrift store and were told that it needed a new lamp (thus the flashing lamp code when powered on) so we replaced the lamp. (mind you the TV screen remains black) the lamp flashes on and off trying to reset itself.....error code flashing is for lamp malfunction/Failure.....but the lamps were replaced and we also attempted to reset the timer. We saw the post about the same problem and we just need to know how to get to the color wheel to clean it and all that other good stuff..... Thanks! Hope someone can help.....soon....fiance broke his neck and needs something to keep him busy!!!!!
    Problem Solver:
  • 7 Answers
Did you purchase just a new bulb? or did you buy the bulb with the cage included?
Posted on Jul 18, 2009
Need a lamp bulb for Sharp 65 inch tv
You could buy it from :-
http://www.purelandsupply.com/56DR650-Bulb-Sharp-TV-Replacement-Bulb.html
Good Luck!!
Thanks!!
Aug 17, 2010 | Sharp 56DR650 56" Rear Projection HDTV
Negative picture,lamp indicator flahing 3 minutes after turning tv off
sounds like your system board is really shot ....did you have a power glitch recently? got backup?
Feb 11, 2008 | Sharp 65DR650 65" Rear Projection...
Upon powering up TV the green light comes on and within a second or two the red light comes on and intermitintly flashes, The tv never comes on?
The lamp or the ballast may be faulty. You'll need to replace the lamp first if this is a DLP. That's the cheapest solution. You can buy a lamp for your TV from discount-merchant.com.
Feb 04, 2010 | Sharp 56DR650 56" Rear Projection HDTV
My tv will not power up. The light comes on and then goes off.
What is Wrong with TV? Have you replaced Lamp? If so and still no picture then it can be Ballast Board it connects to Lamp Box , Ballast is what turns Lamp on Call Encompass 1-800-638-3328 or Mats 1-800-628-1118 and you can also look up Parts on E-Bay!
Sep 29, 2009 | Sharp 65DR650 65" Rear Projection...
Sharp 56DR650 won't turn on
the 32 message indicates lamp issues. Buy a new lamp with new cage and that should fix the problem.
May 30, 2009 | Sharp 56DR650 Television
56" sharp 56dr650 rear projection tv
Hi - wanted to let you know that I have the same problem and I contacted Sharp (800) 237-4277. They offered me a prorated exchange. Select #1 prompt for Operations and then they will create a case number if you don't already have one and then send you over to the Disbatch Dept. They are picking up my 56" TV and are selling me a LC52"D65U for under $450 current retail value of the new TV $1900. Give them a call and see if they can work out a deal for you too. The whole transaction will take 7 - 10 days. Good Luck!
Dec 10, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Lamp already needs replacing
This TV was made in taiwan for sharp & this is a constant problem Complain enough to sharp & consumer affairs & sharp will repair it
Nov 01, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 shows power but wont turn on, Sometimes it turns on
That's error code 32. Indicates lamp trouble or failure. The system will shut down automatically.
Aug 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Tv swithches off and on.
You have a lamp failure. Replace the lamp. Reset the system ( On the remote hold the "menu" and "volume" buttons down until the system screen appears) and you should be ok assuming that the power circuits for the lamp are ok.
Aug 24, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56dr650 Won't turn on, error code>
remove color wheel,seperate from bracket open and lube and clean motor will work fine
Jul 16, 2008 | Sharp 56DR650 Television
Sharp 56DR650 Television Logo
419 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
