Question about Porter Cable 3-1/2" Magnesium Coil Framer Drives 15°ree. Wire Co
Plastic gear broke
The plastic gear inside top of nailer is in peaces,can you tell me where I can find repair specs for the coil framing nailer it is 350 mag by porter cable
    President:
  • Porter Cable Master
  • 1,388 Answers
Porter cable parts are available at www.toolpartsdirect.com. I believe that the part you need is also available by itself and in a repair kit from your local dewalt repair center.
Posted on Nov 25, 2008
How do I get the cap top of a Hitachi framing nailer back on.
NV65AD3 or that kind of ?
NV90AB2
on the biggest transparant plastic part that will fitt on the upper part and the squill will fitting in. with a well-fitting pipe wrench that fits just in the rounding so you can control it somewhat fix the upper part in a bench vise then push with the pipe wrench around 20 mm or maybe some bigger it to its place and with both hands you can push it on place, a plastic hammer is not allways necessary .
May 09, 2016 | Hitachi Tools & Hardware - Others
What is the difference with different angle framing nailer
20 degree are plastic correlated and 28 degree(Bostitch) is wire correlated and 32 degree angle nails are paper tape correlated and lastly coil framing nailers are 15 degrees.
Oct 05, 2014 | Tools & Hardware - Others
Rebuild porter cable framing nailer
This model suffers from cylinder seal failure (large plastic seal sitting on top of cylinder) and sticking headvalve. Easy to fix however. Remove head and pop out the headvalve . Lube the headvalve orings with white grease and reinstall. Replace the plastic cylinder seal with Ridgid seal #079020001013, same part as porter cable but cost less. Good luck
Jan 09, 2014 | Porter Cable Cable No. FR350A Rnd Head...
Where is the serial number on bostitch coil nailer?
The serial number on the coil nailer is towards the air nozzle on the handle. There is a little bridge of metal connecting the main body of the gun to the plastic coil housing. The number is laser etched into that metal.
Apr 24, 2012 | Stanley Ring Repair Kit KTBO650 for...
The plastic gas inlet connection is missing
If you mean the plastic top for the gas cylinder you should get 1 with every box of nails containing cylinders purchased.
Jan 20, 2011 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
Do I need to lubricate my Bostitch F21PL nailer from time to time? The reason I asked is, I got this new nailer. Installed Galvanized 2.5 inches nails from Bostitch and with the metal connector installed....
This is a fantastic nailer, very powerfull. Information about your nailer can be found below.
http://www.bostitch.com/default.asp?CATEGORY=BOS_FRAM_NAILER&TYPE=PRODUCT&PARTNUMBER=F21PL&SDesc=21%26%23176%3B+Industrial+Framing+Nailer+System
You should not need to lube the rails for the nails to feed. Your nailer uses plastic collated nails and should travel very easily inside the rails. I would remove all the nails and check for broken pieces of plastic from nail strips. Feeder should feel snug within rails and not wobble and spring should pull tight. When you install the nails do not release feeder against the nails with force as this could break the plastic strips and cause jam. Nail not feeding is usually caused by wrong nails, weak pusher spring or pusher guides broken /missing. Simple test for proper nails.
Place a strip of nails on the outside of the rails aligned with the edge of the rails and see if the first nail is perfectly aligned with the path of the driver. If the head of the first nail is angled back slightly from the path of the driver, the nails will not feed properly. Good luck.
Jul 17, 2010 | Stanley Bostitch F21PL Nailer
I am having problem with my Dewalt D51823 Framing Nailer- air started leaking out of the nose always when is plug to the compressor. the gun is immaculate inside. quite annoying the compressor keep...
Either the plunger has not completely returned to the "pre-firing" position, or there is a defect in one of the o-ring seals. Make sure that the gun is sufficiently lubricated and if so, then next check the condition of the o-rings. An improper seal will cause this. It is also possible that the trigger assembly has a small crack/leak.
Dan
Jun 11, 2010 | Dewalt Heavy - Duty 31° Clipped Head...
How do i adjust the sensitivity on my nailer right now you have to hit the tip really hard to get it to fire and it is very hard to use i have switched triggers and that fixed nothing it is a bostitch coil...
Usually the pin on the tva6 valve is worn (slightly shorter). You could replace the valve or try adjusting the safety foot to pusher the inner part of the trigger higher into the valve. If you have a green tva6 valve the pin is usually plastic and wears fast. The new tva6 white valves have a metal pin and works better. Good luck.
May 14, 2010 | Stanley Bostitch Coil Framing Nailer
For the Dewalt d51844 can you use PAPER or plastic collated nails
Yes you can generally interchange the two (paper vs plastic collated) as long as the nails meet the specifications (and collated angle) specified by your nail gun.
Please rate this solution on FixYa!
Thanks.
Apr 01, 2009 | Dewalt D51844 Framing Nailer
Problem accessing nails
Hi, No you can't. They are two different feeds. The F33 uses tape feed and the N79 uses stick feed. The N79 is a basic wood frame nailer that uses 3 to 3 1/4 sticks, while the F33 uses up to 2 1/2 paper feed. The stick nails are the most common for the older nailers and on the box look for Bostitch as the brand to fit, as the N79 was sold under that brand not Stanley. This should Fixya!
Mar 02, 2009 | Stanley F33PT Paper Tape Framing Nail
Porter Cable 3-1/2" Magnesium Coil Framer Drives 15&degree. Wire Co Logo
139 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
