Question about HP Pavilion ze4560us Notebook
Usb 2.0 on pavilion ze4560us
I looked at the specs on and believe it or not this motherboard has 2 usb 1.1 ports so the computer is functioning as designed. If my brother needs 2.0 I will help him buy a 2.0 pcmcia card. I find it rather surprising but this is what they say that it has.
  • HP Master
  • 6,487 Answers
This computer only has a USB1.1 support, this is the complete specs for this computer check this link
Posted on Oct 21, 2008
HP Pavilion p6310y Desktop PC front panel wiring
Hello here is the homepage:
The front panel connector look like this:
It`s located down the right corner of the mainboard.
Good luck
Dec 27, 2012 | ASUS M2N68-LA Motherboard
Need circuit diagram for HP m8100 GC673AA
HP Support > Pavilion Media Center M8100n Desktop PC > Main Support page,
Product information > Product specifications > Motherboard Specifications, MCP61PM-HM (Nettle2 {HP name} ),
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires connect to, is the Front Panel header.
(Power On switch, Power On LED, HarDDrive activity LED, etc)
The Front Panel header is Black, rectangular in shape, and is situated in a vertical position; located in the Bottom Right corner of the motherboard. (Next to the mounting hole)
It is a standard 9-pin HP Front Panel header,
Scroll down to the 9-pin Front Panel header photo, and pinout.
The 4-pin side is the EVEN side. Pins 2, 4, 6, and 8. There is NO Pin 10.
The 5-pin side is the ODD side. Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light Emitting Diode, so it is redundant to call it a light)
Pin 1 is for the Positive ( + ) wire.
IF the HDD LED is dim when the harddrive is active, (IN use), switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Reserved for factory use, and it is +5 Volts.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
Scroll the HP Support Motherboard Specification page down. Click on the + sign next to Motherboard Layout.
Left to Right on bottom edge of motherboard, Internal Connectors;
AUDIO_1 is for the audio ports on the Front Panel.
ATX_IN is where the small audio cable from the optical drive plugs in.
(CD/DVD drive)
IF TWO optical drives are used; the Main, or Primary optical drive, is connected with the small audio cable. NOT the secondary optical drive.
HD_AUDIO also connects to audio ports in the Front Panel.
May be mistaken, but don't believe SPDIF_OUT header is used.
1394A1 header is for the Firewire ports in the Front Panel (1394a)
USB 2 and USB 4 headers are for the Front Panel USB ports.
USB 1 and USB 3 should be for a Card Reader.
Need where the power cables go, and what they look like? Just post back in a Comment.
(Be SURE to FOLLOW Anti-Static Precautions)
[ Didn't think you actually wanted an actual circuit diagram. That is copyrighted by HP, and Elitegroup Computer Systems. (ECS)
Dec 03, 2012 | Computers & Internet
One USB port outlet of my laptop is not working.
Interestingly some USB ports can not power all accessories that are plugged in to it. Try another port, if that works you're still in business. I believe that unit has at least 4 ports to use.
Jan 06, 2010 | HP Pavilion dv9700t Notebook PC
This usb device can perform faster if you connect it to a hi speed usb 2.0 port. I have an hp pivilion dv 6000, and according to the specs, I have usb 2.0, but I get this message every time I plug my flash...
This is just an error message. Yes, your HP Pavillion has USB 2.0, but there's a possibility that your USB flash drive has USB 1.1 specs.
If the flash drive has USB 1.1 specs, you would still get the same message. Again, this is just a message because USB 2.0 is backwards compatible with USB 1.1.
Have a great day!
Oct 10, 2009 | HP Pavilion dv6000z Notebook
RAM Upgrade HP ZE4560
Here are the specs for the memory in your system.
Memory Type
DDR-266 (PC-2100) SODIMM
200-pin SODIMM
Maximum Memory » 1024 MB
Is this what you bought? If not take it back and get memory that matches the specs above.
Jun 17, 2009 | HP Pavilion ze4560us Notebook
Hp pavilion a1547c motherboard,is there a serial port connection?
There is no serial port (or parallel port either) on this board. Here is a link to HP's site for all the information:
Nov 22, 2008 | Computers & Internet
Pavillion ze4560us
dude usb 2.0 was released way back... i believe the necessary drivers have not been installed... you better go to device manager and try updating the drivers... it would have option to check online... post here if u need more help...
Oct 18, 2008 | HP Pavilion ze4560us Notebook
P4p80 vm - usb 2.0 help
It might be on a different usb port . Some computers have different ports like one will be usb 1 and another will be usb 2 .
Check for other usb ports on the computers outer case and try them all.
Mar 30, 2017 | ASUS P4P800-VM MB, 865G/ 800FSB/ SATA/...
Trying 2 figure out what type of memory 2 use?
that looks like an Albatron MoBo but I cant get onto the albatron website to confirm this
AMD Athlon™/Athlon™XP/Duron™Processor
Socket 462 with FSB 200/266MHz
2 DDR266/200 Memory Sockets
6channel AC 97 Audio
2 ATA133 Channels, up to 4 ATA 133 IDE Devices
6 USB 2.0/1.1 Ports (4 ports by optional cable)
Integrated 3D Graphics Engine
Socket 462 AMD Athlon™/Athlon™XP/Duron™Processor
FSB / Transport
North Bridge: VIA KM266 ( VT8375 )
South Bridge: VIA VT8235
I/O Chip : Winbond W83697HF
2 * DDR sockets
DDR266/DDR200 unbuffered ECC/none-ECC DDR SDRAM up to 2GB
Expansion Slots
1 x AGP 4X slot (1.5V Only)
3 x PCI slots (PCI 2.2 compliant)
1 x CNR slot (AMR Type)
IDE / SATA Connectors
2 ATA133 channels, up to 4 ATA 133 IDE devices
Onboard I/O Connectors
1 x Floppy Connector
2 x USB 2.0/1.1 header (4 ports USB cable optional)
1 x CD_IN header
1 x COM (serial) port header (Optional COM cable)
1 x S/PDIF in/out header (S/PDIF in/out cable optional)
1 x CPU fan header with fan rotation detection function
1x System fan headers with fan rotation detection function
2 x 5 pin system panel header (Intel spec)
1 x Front audio header (Intel spec)
1 x IrDA header
1 x Case Open detection header
1 x Wake on LAN
I/O via Back Panel
PS/2 keyboard/mouse, 2 x USB(2.0/1.1),1xVGA ,1 x Com(serial), 1 x Parallel, 1x Game/Line-in/Line-out/MIC
20-pin ATX power connector
BIOS Feature
2Mb Flash EEPROM
Award BIOS with ACPI, DMI2.0, PnP, WfM2.0, Green Suspend to RAM (S3), Suspend to Disk (S4) Wake on keyboard, Wake on LAN/RTC Timer
Hardware Monitoring
2 FAN sensors, CPU/System voltages and temperature monitoring.
Special Feature
Form Factor
Micro-ATX (218mm x 244mm)
Jul 11, 2008 | Intel Motherboard
HP Pavilion ze4560us Notebook Logo
118 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
