Question about Hitachi 53UWX10B 53" Rear Projection Television
Thought I had a convergence problem - red is still broke
I thought I had run into the famous convergence IC problem. I purchased and replaced the convergence ICs. Now when in the grid, I cannot get the red to align. It looks okay in the center, but gets way out of whack on the edges. Any suggestions?
I'm hopeful that perhaps there's just something I missed - but if this means replacing the red gun - this set is headed for the bottom of the nearest lake.
  • 61 Answers
KCOZI,
I dont think you have problem with Red Gun.
One of your Convergence IC is faulty with 2 RK series Resisitor(Low Value) in Convergence
Amp Borad.If you changed IC look for RK series Resistor (may be 3.9ohm/2.7ohm)
Dont forget to Rate!
Good Luck
Dals123
Posted on Oct 21, 2008
SOURCE:
Double photo
Replace both of your STK ICs STK392-110s use 150s Mats has Them 1-800-628-1118
Jun 02, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My tv is displaying a double picture.. i pulled the back off and covered the red lamp and the picture goes back to normal but no red in the colors.. pull my hand off the red lamp the picture doubles...
Problem cause is red convergence output chip failure that will be replaced to fix the issue.
If you have experience of electronics stuff repair and can replace parts in circuit board as it requires soldering work with proper tools then can replace convergence output IC in your tv by yourself.
Let me know if you have additional question.
Thanks.
May 03, 2010 | Sony KP-51HW40 51" Rear Projection...
On my mitsubishi ws65909 I have a 2-2 power light error code, what does this mean? any suggestions, I tried to power it up and the power light comes on and then goes off after 15-20 sec's
the famous code error 2- 2 is for fault in power supply or faulty power supply board. this has to be checked.
and error 2-3 is fault in convergence ic.so both the error codes are near to each other.so check out both options. i advise first replace the convergence ic on the board and check.the cost of each convergence stk ic is near to $15 .there are two such ic on the convergence board and both has to be replaced.then check out.if the problem is same go for power supply board replacement.
the ic which you have to remove and replace is stk 393-110 both the ic looks same anve same number .
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 26, 2009 | Mitsubishi WS-65909 65" Rear Projection...
I have a 2002 Panasonic Model PT-47WX42F I have a red shadow in the screen. In other words when you see the channel info there is a red shadow of the same info. Whats broke? Mike
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge between $200-$300
Sep 26, 2009 | Televison & Video
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
have pts rebuild the board which will cost around $130, www.ptscorp.com, or replace the stk392-110 x 2 located on the convergence panel.
Dec 08, 2007 | JVC AV-48WP74 48" Rear Projection...
Convergence problem
At present, bad connect(s) on red convergence IC. Soldering pins will fix temporarily.
Usual fix = replace STK392-110  IC's. A 400.00 dollar repair at
your local tv shop......T.
Oct 24, 2007 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP920217F Convergence Problems
replace ic chips pt# stk392-120 or stk392- 150 and there are 12 resistors located near ic clips pt# 6r8 ( color code blue - gray - gold - gold ) board location no#s 3149 thu 3160 if you look close you may find two resistors discolored as i found on my convergence circut board , also use heat sink compound on new ic chips , take your time to mark all wire connectors going to board from tv , also use .022 dia gage rosin -core solder and a 15- 25 watt soldering iron you may have to adjust the red - blue convergence afterwards my tv set is 3 yrs old also ( thanks holbert )
May 03, 2007 | Philips 60PP9202 60" Rear Projection...
Convergence circut
Usually there are 2 convergence IC's, labeled STK392-110. Each IC has 3 channes. Each color needs to be corrected 2 ways, vertically and horizontally, so 6 channels are needed. usually one IC does red, red and haf of green while the other IC does the other half of green, blue and blue. If the red colors are off, change the IC closest to the red jack. If the blue is off, change the IC closest to the blue jack. If the green is out, you have a 50/50 shot at replacing the correct IC. It is recommended to use the STK392-150 when replacing the IC's so it might not be a bad idea to go ahead and replace both with the newer numbers.
Apr 11, 2007 | Hitachi 46UX24B/25K 46" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
