Question about Husqvarna Designer I
Brother pro 600 embrodiery machine
Error reads main motor error and needle position erroe
You may have a bent bar inside the machine (big trouble), needle error is easy it is just to wind the big nob at the back of the machine, make sure you are on the correct needle when you move it, on mine it is a little stiff, just do it slowly. The engineer just bent my bar back into shape, that was 1yrs ago. Good luck have fun :-)
Karen (wytchstitch)
Posted on Jan 04, 2009
  • haishali Mar 29, 2012
    Please help me asap:
    My brother embroidery machine PR620 shows "main motor lock" if I close the error, it shows "inappropriate needle position" if I close this error too than "main motor lock" error comes back...
    Please help me with solution asap.
What is the best course of action.I have a 10 needle baby lock Plus, today my "Main Motor Current Error" appeared on display screen. I shut off for short time and started again. Is there anything i can do...
From the Brother web site I find, " If you are receiving a "Main motor current" error message indicates there is a problem with the unit, and it is recommended that you get the machine serviced.
Take your machine to the nearest Authorized Brother Service Center for repair.
You can locate a Brother Authorized Service Center (ASC) in your area by clicking on the link below. or contact Brother Customer service by calling 1-877-Brother (1-877-276-8437) Monday through Friday, excluding holidays.
Service Center Locator
Feb 21, 2015 | Baby Lock Sewing Machines
Brother galaxie 3000. error msg saying thread tangled/needle broken? its neither, and the machine will not work until it's cleared. help!!
This is an error generated by an overcurrent on the motor. does the machine turn freely with the power off? My guess is that the upper main shaft bushing has seized. If so you are in for a big job remove shaft and bushings, work bushings free and then reinstall.
Jan 27, 2015 | Brother Sewing Machines
Main motor lock, inappropriate needle position, after broken needle
The broken needle may be lodged in the bobbin housing. If you cannot locate, take it in for professional servicing. You may have put the timing out of whack.
Mar 09, 2014 | Brother Sewing Machines
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
E-4 error Brother
Error E-4: The reverse/reinforcement stich button, needle position button or thread cutter button was pressed while the bobbin winder shaft is moved to the right
Mar 28, 2010 | Brother CS-100-T Computerized Sewing...
Brother PR-600...does anyone know if it's a major problem if it says "main motor lock"? The needle broke while sewing, and it is stuck in the down position and will only say "main motor lock" on the...
I took the case off, and was able to raise the lever, and am NOT getting the error msg anymore. However, now machine is out of time (I think) I want to fix it myself...can I?
Nov 04, 2009 | Brother Sewing Machines
Needle securing screw
My PR600II error message main rotate error. what can i do to fix it
Nov 29, 2007 | Brother Sewing Machines
Sewing Machines Logo
197 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
