Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Problems witha toshiba rear projection 2002 50h71 model
The problem began when hooking game system up to tv , you would get moving horizontal lines at top of screen, but would go away after tv was on for awhile. then changed satelite compainies after new company installed the horizontal lines have not gone away. any help would be great.
thanks, c
  • CLEBonehead Dec 27, 2008
    Yes I do have the same issue, but mine seems to go a little further. In video mode the system is in a "scramble" type picture. I was in hope to find the "cure". Is this tied to Plugging and Unplugging video Game systems into the television while on? Or does this occur just because the games are on the television?
    Genius:
  • 1,030 Answers
Sounds like you might have the hypermodule capacitor problem. there is a cuircit board in this set that has 11 very very small capacitors that go bad this is charistic of wavey lines that go away after warming up. and eventally not going away. we repair about 2 of these a month at our shop. we would loved to just replace the board but this board is not availble we cant find it. so we very carefully resolder these caps. with magnifers and twezzers. so i dont recomend anybody attempt this except experience technician., you can easly damage this board and once damaged u cant find the board.
Posted on Oct 21, 2008
Blurry Picture on Toshiba 65HX81
yes the tv has convergence problem u will need a tech to reposition it
Jul 11, 2013 | Toshiba 65HX81 65" Rear Projection...
Hi , i have toshiba 43" rear projection tv, the picture is not stable and bouncing all the time and the colors are oufull mainly blue red and green, what can it be ? are the lamps are finished ? the...
I would like to view that short video clip to diagnose possible cause of picture problem and would you please confirm model number of tv that would be written at rear?
Thanks.
Apr 29, 2011 | Toshiba 43A10 43" Rear Projection...
The screen on my toshiba 50h12 is messed up. its as though the horizontal is not matching up...how can i fix this myself?
It sounds convergence out chips got bad in your Tv and causing problem. Replace convergence out ICs in TV if you are familiar with electronic stuff repair.
Required parts are available in Part Store.
Dec 24, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba 46H83 HD Projection TV with distored picture
if you are using an areal for your tv move your areal and see if it works or do the tuning for it .
Apr 19, 2009 | Toshiba 46H83 46" Rear Projection...
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 13, 2017 | Apex Digital GB43HD09 43" Rear Projection...
Toshiba 50A61 Horizontal Lines in picture
You have bad connections somewere need to look further for sure
Nov 08, 2008 | Toshiba 50A61 50" Rear Projection...
Samsung hln567w Gray horizontal lines
have you tried a system restore to get your resolution back?
You may then try to take a different path in fixing your problem.
if you cant system restore try installing the previous driver you had.
could you post up what your "computer problems" were exactly?
the more info the better*
We may know another solution for it other than updating your driver and losing you resolution options
Aug 23, 2008 | Samsung HLN567W 56" Rear Projection HDTV
Black horizontal line moving across screen with PS3
Loose connections in the AV board. Re solder . Did you try in video 2 or 3 ?....But Am suggested re solder AV board and connectors. I hope this help you I am here any time thank you!!!
Jul 21, 2008 | RCA P52926 52" Rear Projection Television
Model 55X70 Toshiba Projection tv
dont know about warranties but horizontal lines means your horizontal frequency which runs about everything has drifted off sync and if too high or low it will activate shut down circuits in high voltage and power suppy, even causing HOT transistor to short. good luck and call a tech.
Sep 01, 2007 | Toshiba 55HX70 55" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
