Question about RCA F32450 32" TV
26in rca colortrak 2000
No picture, makes a clicking sound when I plug in the set.
    President:
  • 3,130 Answers
Very common problem The Highvoltage transformer and the horizontal output transistor has to be replaced. If you have no tv repair experience, this is not a repair for you. seek a professional. Should cost about 175 to 225 for this repair. Good Luck
Posted on Jul 12, 2006
How do I hook up my ps3 to my rca colortrak?
would be best to get a old vcr, then with a cable you hook it to the vcr and play it thru the vac
Mar 03, 2015 | RCA Colortrak 2000 Tv Large Tube Screen Tv...
Rca colortrak 2000 manual
You may be able to get a manual by requesting it directly from RCA.
Jul 28, 2014 | RCA Colortrak 2000 Tv Large Tube Screen Tv...
I have a RCA colortrak 2000 picture tube TV . There is one horizontal white line in the middle of the black screen
You have a vertical problem, caused by vertical deflections circuit failure, can involve a number of parts to fix.
Jan 03, 2011 | RCA Televison & Video
I have sound but not picture when I play vcr. I
I believe that channel 00 switches the set to the A/V inputs on the rear panel. You may have a bad cable or loose connection. Make sure the RCA plugs are firmly in the jacks at both ends.
The trouble may also be in the VCR. Sound but no picture is often a symptom of dirty heads. Try using a wet-type cleaning cassette and see if that brings the picture back. Wet-type cleaners come with a bottle of cleaning fluid which you apply to the strip inside. It's much more effective than dry type cleaners.
Mar 21, 2010 | RCA F27252GY 27" TV
Old RCA ColorTrak
HELLO. YES U CAN IF YOU CAN GET A DEGAUSSER.!!! U CAN GO ON LINE AND FIND OUT HOW TO MAKE ONE AT UTUBE.COM. TYPE IN HOW TO MAKE A DEGAUSSER COLE.!! THEN FIND OUT HOW TO USE IT.!!! THERE ALSO.!!! GOOD LUCK.!!
Jun 22, 2008 | RCA Televison & Video
TV has sound but no picture RCA ColorTrak 2000 P52150CP
If I had a model # it would be helpful but my guess is the deflection circuit failed and a fuse opened in that circuit. Could be vertical or hoizontal circuit failure but either way you will need test equip. as well as solder/desolder equip. to repair it. If set is over 10-12 years old you may consider replacing set in this case Sorry I can't be more help.
Jun 02, 2008 | Televison & Video
No sound
If you are using a cable box try patching the audio from the box to your stereo system. If that does not apply to you, then getting the set fixed or replacement is in order. A colortrack 2000 is like 20+ years old. They don't make them like that anymore., Too bad.
Mar 24, 2008 | Televison & Video
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
Rca colortrak 2000
what is the chassis number of your set should be a ctc or ptk number?Post hat info and I should be able to give some advice on whats happening with your set.
Feb 18, 2008 | Televison & Video
RCA 26in.
Bad solder connection..small coil in horiz driver circuit near
center of circuit board....solder both leads even though they
look good..........................T.
Jan 08, 2008 | RCA F27442 27" TV
RCA F32450 32" TV Logo
116 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
