Can you please advise the voltage and current output of the plug pack used to charge the batteries of a Digitor Cordless Drill model T4818. I've found one at work and can use it although the plug pack has gone walkabout...
The drill is 18V but the charger takes 24VDC and around 800mA.
Trial and error always works.
Posted on Oct 23, 2008
  • 537 Answers
I think the voltage is 18V. I'm not sure on the current. I would just call the company and ask them
Posted on Oct 21, 2008
With the new battery (non original) I brought my keypad locks up and I have to put my old one back in again before I can press anything on my keypad. Why would a battery affect usage? Geoff
non original battery might vary the output voltage and in turn it will affect the normal working of the PDA, so it is advised to use only original battery.
Jan 08, 2011 | Computers & Internet
My e 6 rockr is not getting charging once i put it on charging its switched on and switched off its keep on repeating
please have the adapter voltage checked for the dc output , have the battery contacts cleaned and checked for the voltage.
If either of the above is low then replace.
if Ok test the voltage at the teminal of the phone after connecting the adapter.
If Ok the battery must charge but if the charge drops off the batttery is faulty provided the functions of the phone are OK.
Sep 30, 2010 | Motorola Mobility ROKR E6 Smartphone
Cant turn on
I advise you to buy a charger with the current and voltage ratings provided on the battery with the USB output and connect the phone with the data cable to get it charged.Or you can directly connect to the computer to get it charged.
Jul 05, 2009 | O2 Xda Atom Exec Smartphone
I put the charger in the phone and it doesnt charge
Try to check your charger and battery 'coz it might be a problem... use a voltage tester... or try to "shock" your battery using a voltage regulator with 12V output voltage... red wire on he positive battery terminal and black wire at the negative... have contact at least 5 sec then try to charge....
Jun 17, 2009 | i-mate JAQ Pocket PC
Will not charge or turn on using USB cable.
Two things.
HTC phones will not charge from the USB port unless you have ActiveSync on an XP or Mobile Device Manager on a Vista PC loaded.
Second, if the phone has been stored for a very long time, 1 year if initially charged, 1/2 year if not, the the battery self discharges to a point the USB port PC Sync software doesn't know the phone is connected. You must jump start a charge on the battery by either and HTC AC charger, a generic AC/USB charger will not work, or you can apply a +5 VDC voltage to the power terminal, marked + and - on the battery case, on the two outside terminals I believe. This 5VDC must be current limited for safety. The Red and Black lead inside a standard USB cable will supply current limited +5 volts at 100MA. Chop off a standard USB cable, their cheap and break out expose the Red and Black leads. While connected to the PC USB port, hold the Red lead to the + battery terminal and the Black to the (-), or other outside terminal, of about 30 seconds to a minute.
Now when you plug the phone to the PC with a good USB, the Amber light on the phone to indicate Charging, may not come on for a while, 5 minutes or so, but it will eventually. If it does not, jump the battery again for a longer period of time.
An AC charger for the 3125 are fairly inexpensive. $7 or so, on ebay with shipping. This may be the way to go. Consider getting one with a new battery. They are sold this way sometimes and sometimes for little more that the charger alone.
Oct 19, 2008 | AT&T Cingular 3125 Smartphone
6630 charging problem
Hi Friends,
I am Raheel Ansari from Pakistan, Karachi. My 6630 's battery is getting discharged very soon I have buy New Batteries but issue still remain. kindly help me out in this regard.
Thanks & Regards,
Raheel Ansari.
Aug 31, 2008 | Nokia 6630 Handheld
I Have a Black&Decker cordless drill. VersaPak. It is a few years old but hardly used. I charge the batteries overnight but don't get enough power to drill all of the screw down....
Thanks anyway but I feel I shouldn't have to pay to find out what is wrong with a product that I purchased from you. In the future I will stay away from your brand name. Martha
Jun 30, 2008 | RIM BlackBerry Pearl 8100
Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Dec 29, 2007 | HP iPAQ H5550 Pocket PC
My Palm Zire 72 will no longer charge
At first, before to want to be sure where is the problem is, you must do these sample tests: 1) Take out your battery and plug your power cord into your phone without battery. If : Power is on, there is definitely, your battery is bad and cannot hold a charge. If nothing happens, your internal battery may be dead and cannot hold charge so all info in your ROM of course has been washed away except the pre-load software by Palm. 2) At this step, you need to open your Palm if you know how to do to check for any bad connection between cable and use your volmeter to check the voltage output of your inner battery or can be called reserved battery whether it is have any power. If your reserved one has correct output voltage as in specs then check all connection around your power supply part to see any crack or defect. Please reviews the link below for detail: http://palmtops.about.com/od/pdarepair/Maintenance.htm I hope these info will give you some hints.
Apr 10, 2007 | Palm Zire 72 Special Edition Handheld
Computers & Internet Logo
90 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
