(New goodman 3 ton gas package unit) I Replaced the board in the unit, I have the same problem with the new board as I did with the original board, the unit will not stop running.I unplugged the thermostat wires in the unit and wire caped I then plugged in the disconnect. The unit starts right up in adition to that my led light is blank I cant see having two bad boards any sugestions
"PLACE A JUMPER (PIECE OF WIRE) BETWEEN Y AND W IF YOU ARE USING A HEAT PUMP WITHOUT AUXILIARY/BACKUP HEAT." if this dosnt work check the fuse in the air handler you may have blown it if you did not turn the unit off before installing.
