Question about Whirlpool MH7155XM Microwave Oven
Whirlpool MH7140XFQ Microwave just suddenly stopped heating. All other bells and whistles seem to work. Trying to troubleshoot and need schmatic. Trying to diagnose without dropping unit. Have had no trouble since safety recall. Any input as to most likely trouble? Any help appreciated! Thanks!
  • 2 more comments
  • mspauld Oct 21, 2008
    Thanks for the quick reply! To answer your main questions, nothing smells burnt, everything sounds normal while trying to operate, I just get no heat. I just pulled the unit tonite and began to troubleshoot, so far HV diode fails! Have not yet finished checking out transformer secondary, filament, magnetron, or capacitor. Am hoping diode is all that is wrong. Any advice on what to use to bleed capacitor to finish troubleshooting? Again, Thanks!
    p.s. - diode tests open
  • mspauld Oct 22, 2008
    Still not working even after replacing diode. Everything else checks out according to tech sheet from inside unit. Seems to be getting 120v to transformer primary, just no heat. By the way, I have never been able to get either diode (new or old) to show any continutiy in the forward direction. I have tried 3 different DMMs with same results. Could I have gotten a bad diode from the parts house or is this just a Fluke? (pun seriously intended). I feel that I am missing something basic. Help with how to check high voltage &/or magnetron side would be appreciated. I suspect that my capacitor is never seeing any charge. Thanks!
  • mspauld Nov 11, 2008
    Reply primarily to B Low:
    Short answer: no I haven't fixed old unit. The details: Got as far as measuring 120v ac across transformer primary while bench testing unit. No way that I know of to verify high voltage/magnetron side without killing myself. All of the troubleshooting measurements given on the unit's spec sheet seem to check out ok on the unit. I give! Went down to the local BestBuy store and purchased a new Whirlpool MH2175XS for around $260, old unit boxed in my garage in case I get bored or if MacGyver happens to come by some time. This is probably not the help your were looking for, but unless your more comfortable working with high voltage circuit than I am or your willing to pay a professional, maybe you gotta do what I did and put a bullet in it's head. Sorry & best of luck!
    ps- If your ever seem to find your trouble, please let me know!
    Mike
Did you get the unit working? I am having a problem with my same model microwave...
Posted on Nov 11, 2008
Sounds like it is the high voltage diode then. A fairly inexpensive part I think
Posted on Oct 21, 2008
  • 537 Answers
Does it make any noise, like buzzing ? Is there a burnt smell? If so it might be a shorted diode or perhaps the magnetron.
I am not sure which part I should be buying so that I can replace it in my microwave. The roof of the microwave has been perferated due to catching fire. It seems the microwave would still heat something,...
It sounds rather like you need a new internal casing. Given that the oven would need to be almost completely dismantled, the cost will likely approach that of a new oven. You might be able to make it an insurance claim.
If you try to fix it yourself, be aware that microwaves usually have a high voltage capacitor in the magnetron circuit, and you MUST make sure this is completely discharged before handling it anytime.
I don't want to post any more information on that here, just to say you would be best off getting a cost estimate from a competent service tech.
Sep 01, 2013 | Whirlpool Microwave Ovens
I have a Whirlpool MH7140XFQ-0 Microwave and last night it stopped working with the screen showing F6. I unplugged it for over an hour and plugged it back in and it went right to F6. It tries to run if the...
"F6" on a Whirlpool microwave means you have a shorted cook relay on the control circuit board.
For model MH7140XFQ0 the control circuit board would be part number 4393919, which you can order from the Pros here for $132.23.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) take out the old board, then move the new circuit board into your frame.
Some connectors on the relays may have a lock:
Otherwise, we regularly repair these boards with our $39.95 nationwide service. Details are here.
Jan 23, 2011 | Whirlpool MH1140XMS Microwave Oven
Whirlpool MH7140XFQ Fuse to Breaker Problem
There is absolutely no way to guess at the problem. You need to troubleshoot the circuitry with a meter to find the failing component
Oct 06, 2009 | Whirlpool MH7155XM Microwave Oven
MH7140XFQ Fuse Amp
you need to look at the ends on your fuse and this will tell you the amperage you need to get for your particular unit,get them from a hardware store
Sep 22, 2009 | Whirlpool MH7155XM Microwave Oven
I have a whirlpool model MH7140XFQ and we got a guy to come and look at it and he said the Mag. tube and the circuit bars were broken. Which would be more expensive to change the broken things or just...
He is referring to the magnatron tube which is the heart of the microwave. Probably more expense than you would want to put in to it.I would recommend replacement unless it is a high end model. Hope this helps
Jul 24, 2009 | Whirlpool MH7155XM Microwave Oven
Whirlpool MH7140XFQ-1 microwave no longer heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
Microwave not working
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Dec 19, 2008 | Whirlpool MH7155XM Microwave Oven
Whirlpool MH7140XFQ
It's most likely caulk. It can usually be sliced with a razor blade.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 21, 2008 | Whirlpool MH7155XM Microwave Oven
Whirlpool MH7155XM Microwave Oven Logo
577 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
