Question about Sony KP-57WS500 57" Rear Projection Television
Picture Fades When I turn the tv on the picture is normal. Within 2 minutes the color fades to blue and goes out completely.
  • Juliette Fenner Jul 15, 2006
    The tv fades to a blue color and stays blue. You can hear the sound but the picture is totally blue
  • 1,476 Answers
It isn't clear if the picture just loses color or the screen goes blank. If you are just losing color (picture goes to B/W) there is a problem in the color circuit and from your description it could easily be a bad solder connection on the board which decodes the color portion of the picture. If you are capable with a soldering iron and know TV HV safety, unplug the set, and remove the circuit boards and inspect (with a high powered magnifier)and resolder all suspect looking connections on the boards. You could also resolder all the connections which is more work but assures that solder joints are not the problem. If your problem is not solved at this point you are probably going to need a technician to look at it as it could be just about anything and probably would be beyond your expertise. Good luck and be safe.
Posted on Jul 12, 2006
Picture fades to black
Find the vertical IC and check for very small cracks on the solder joints of its pins and resolder (approx. 10 Pins). Also check in the same area for a 1 micro farad at 50 vdc capacitor that goes bad and replace it.
Dec 18, 2013 | Toshiba CX32F60 32" TV
The screen turns blue after about 2 minutes of turning on the TV
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 25, 2010 | Sony KP-57HW40 57" Rear Projection...
Picture fades in after 2-3 minutes
you do have a defective crt.
Jul 25, 2009 | Televison & Video
Picture comes on then fades to blue
Check the info from this website to see if you are able to fix your TV. You should turn the blue screen control down slightly counterclockwise. If that did not work, then more likely you have a video amplifier IC defective or a blue CRT.
Dec 19, 2008 | Sony KP-57WS500 57" Rear Projection...
Picture fades in and out
filament circuit look for glow neck of crt. make sure socket on firmly.
Dec 02, 2008 | Samsung TXE1986 TV
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony Kp-51hw40
Sounds like a bad solder connection in the sweep power supply. Not a repair for the novice I'm afraid. If you get it fixed before the set goes out completely, it should not be that expensive of a repair. Good Luck
Jun 03, 2007 | Sony KP-51HW40 51" Rear Projection...
Portable Grundig TV/vcr combo - screen goes blue and then set switches off.
Hi mcloud Your problem is your video circuit.the component could be faulty or it has lose solder.have a tech look on your set for repairs.good luck.
Apr 25, 2007 | Grundig GF70-600 TV
Sony KP-57WS500 57" Rear Projection Television Logo
143 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
