Question about Legacy Car Audio & Video
I need a plug how do i find one - Legacy Car Audio & Video
    Problem Solver:
  • 13 Answers
What type of plug are you talking about?
Posted on Oct 21, 2008
Steps to change a spark plug
easy job replace one spark plug at a time.you need buy new set of spark plug wires and spark plugs.reason need new wires possible old ones will break from inside plug boot when you remove plug wires.you need basic 3/8 ratchet wrench.you need long short extensions.need spark plug socket.need spark plug gap gauge.need a universal joint connect to the extensions to reach sharp angles.make sure engine cold when replacing spark plugs could damage heads.use a 12 inch piece vacuum hose to help aid in installing sparks in hard reach spaces with out damaging crosss threading plugs threads and cylinder head threads to plug.
Apr 25, 2013 | 1998 Pontiac Grand Prix
Need to replace sparkplugs on 2002 ford escape
well replace spark plugs is not a hard job,when replacing spark plugs, good time to replace plug wires also.you need to replace one spark plug at a time so you wont mix up firing order. you need a spark socket, torque wrench, 3/8 ratchet wrench, 3/8 short and long extensions,you need a spark plug gap gauge.spark plug gap for 2.0 engine 0.051 the 3.0 engine spark plug gap is 0.052 - 0.056. just follow spark plug wires they will lead you to the spark plugs.warning wait until engine cool down first because removing spark plugs from hot engine could damaged the aluminum heads,use compressed to blow away debris before removing spark plugs keep debris falling into the cylinders.wear safety glasses if you use compress air and use small amount anti seize compound to the spark plug threads.good idea slip a short length rubber hose over the end of spark plug to use as a tool thread it into place.reason i use piece vacuum hose it will grip the spark plug enough to turn it, but will start to slip if the plug begin to cross thread.when installing spark plug, it should turn at least few times if spark plug start tighten before 1/4 turn thread cross threading need to back off start over dont keep turning you will stripped spark plugs threads in the head also damage spark plug threads, so be careful, good luck with job.
Aug 26, 2012 | 2002 Ford Escape
My spark plugs in my 2004 Mitsubishi Endeavor needs to be changed, and my husband wants to do it himself so is there some way to give me some instructions on how to change spark plugs for my 2004...
YOU NEED LONG SPARK PLUG SOCKET. NEED A 3/8 INCH RATCHET WRENCH.YOU NEED EXTENSION.YOU NEED SPARK GAUGE YOU NEED A TORQUE WRENCH. NOT MANDATORY JUST DONT OVER TIGHTEN SPARK PLUGS STRIP ALUMINUM THREADS WAIT UNTIL ENGINE COOL TO KEEP FROM WARPING THE HEADS. SPARK PLUGS LOCATION ON TOP OF CYLINDER HEADS.TO GET TO SPARK PLUGS THE COILS ON TOP EACH SPARK PLUG.HAS TO BE REMOVED BY REMOVING SMALL SCREW.THAT HOLD COILS DOWN.AND CHANGE ONE SPARK PLUG AT A TIME SO YOU WONT GET THEM MIXED UP.GAP PLUGS AT 0.028 - 0.031
Jan 28, 2011 | Mitsubishi Endeavor Cars & Trucks
Engine missing wont fire properly, i think its the spark plugs how do i change them ?
CHANGE SPARK PLUGS.YOU NEED SPARK PLUG 3/8 SOCKET.YOU NEED SHORT AND LONG 3/8 EXTENSIONS.YOU NEED SPARK PLUG BOOT PULLER AND A SPARK PLUG GAUGE SET THE SPARK PLUG GAP.NOW CHANGE 1 SPARK PLUG AT A TIME SO YOU MIX THEM UP GET FIRING ORDER MIX UP CAR BACK FIRE WONT CRANK.ALSO CHANGE PLUG WIRES ALSO.
Nov 10, 2010 | 1994 Honda Civic
I need to change the plugs on an 05 Trailblazer what is the best way to do it?
Remove the rubber boot carefully. Might want to grab ahold of the boot and turn in back and forth to break it free abit then pull the boot off. 5/8 deep socket with the spark plug insert will help keep the plug in the socket as you pull it out.
-david
Nov 06, 2010 | 2005 Chevrolet TrailBlazer
When should plugs need to change?
it depends on the plugs that are installed in there now the standard plugs can go upto 60000 miles the platium plugs are suppose to go 100000 mles but ive seen a lot of platuins plugs that didnt make it that far.
May 30, 2010 | 1996 Chevrolet Caprice
How to change plugs on honda odyssey 2005
you will need
8mm
10mm
5/8 spark plug socket
3/8 ratchet
3/8 extension (it could be 4in and longer)
and spark plugs factory plugs are pregap iridium
spark plug torque is 13.0 lb.ft
coil torque 8.7 lbf.ft
spark plug part # NGK 1zfr5k-11
# DENSO pkj16dr-m11
and spark plug anti seize on spark plug thread
what you need to do is remove the plastic cover 8mm socket or 10mm sockets
now remove the spark plug covers and remove the spark plug coils too 10mm head bolt you will need a 5/8 spark plug socket and a 3/8 ratchet and a 3/8's extension too
you need OEM spark plugs they work the best
hope this will help
May 22, 2010 | 2005 Honda Odyssey
Remove and replace spark plugs
not to bad you'll need long extension, front one are there in view, the back one's remove spark plug boot (long one) and with extension you can reach spark plug's.
Dec 11, 2009 | 2000 Mazda MPV
How to change the spark plugs
if its your first time you need a haynes repair manual.you need a spark plug boot puller.you need 3/8 ratchet wrench.spark plug sockets.from size 5/8 to 13/16.you probably need size 5/8 socket.you need extensions different sizes.and universal joints.to reach hard to get plugs.you need torque wrench. and spark plug gap set.
Jul 07, 2009 | 2002 Kia Sportage
Car Audio & Video Logo
22 people viewed this question
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
xxxxxx xxx
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
