Question about Maytag Neptune MDE5500AY Electric Dryer
Sensor dry level
Isn't there supposed to be a dry level choice with all the dial options? Mine only shows with the top 2.I can't remember and wonder if I need to get it fixed. thanks,
  • Maytag Master
  • 2,651 Answers
Quite possible that only a few selections will allow you to override "dryness" level feature. certain options are preset and dont alllow change.
Posted on Oct 21, 2008
Barrel isn't turning.
I believe you will find the belt is broken.
There is a motor which is supposed to turn a belt, which in turn drives the drum.
If you wish to repair ir yourself, a letter to "Fixya" could cause someone to walk you through the steps.
Be blessed.
Mar 04, 2013 | Frigidaire FGR641FS Gas Dryer, White, 5.7...
Dials on top of a brother XR-65, what are they suppose to be set at??
Usually they come from the factory at mid-way. But that isn't a "supposed to be" situation. Each fabric will have it's own settings. What are you trying to do "get it back to normal?"
Oct 25, 2012 | Sewing Machines
My drier was on the sensor cycle and was supposed to run for 54 mins. It was still drying over 2 hours later and the display showed there were 42 mins remaining in the cycle. The clothes were completely...
More than likely the temperature sensor has gone bad. If the unit is under warranty I would contact the dealer...otherwise you need to replace the sensor.
Sep 01, 2011 | Samsung 7.3 Cu. Ft. Super Capacity...
What is the dial on the top of the cam. suppose to be set on to take a picture? it's a vivicam5386
According with the conditions to take a pic, could be select the next choice...
I suggest download and check this User Manual for this and other details: Vivitar ViviCam 5386
Good luck (remember to rate and comment this answer).
Jul 05, 2011 | Vivitar ViviCam 5386 Digital Camera
P0463 Fuel Level Sensor Circuit High Input Any ideas on the problem and possible solutions?
P0463 - Fuel Level Sensor Circuit High Input
An excessively high voltage is sent from the sensor is sent to ECM.
The fuel level sensor is mounted in the fuel level sensor unit. The sensor detects a fuel level in the fuel tank and transmits a signal to the ECM or PCM.
It consists of two parts, one is mechanical float and the other side is variable resistor. Fuel level sensor output voltage changes depending on the movement of the fuel mechanical float.
- Engine Light ON (or Service Engine Soon Warning Light)
Possible causes
- Fuel level sersor circuit harness or connectors is open or shorted
- Fuel level sensor may be faulty
Possible solution
Replaced fuel level sensor.
Hope helps (remember to rate this answer).
May 07, 2011 | Ford Explorer Cars & Trucks
I activeted my nokia 6300, IMEI- 355206034413587 . security level as memory but security code does not work.
Just follow the steps
Make a backup of contacts in your another sim.
Switch-off your phone.
1. Press and hold theree keys at a time;
You will use three finger for pres three keys .dial switch 3 key(from key pad) star( *) and pres the on switch.
Green dial key,
* Star key,
No. 3 key
Then Power on/off to swtich on the phone.
All switch will be pressed at a time.
.Soon an formateing text, will appear ,then stop pressing those switch, remember. 2. After a few minutes when the Full
phone formatting completed, your phone will back to original system and factory settting.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Hope this helps.
Jan 16, 2011 | Nokia 6300 Cellular Phone
My camera has lost the ISO settings... it now only shows Auto and High. Also the flash only shows Auto and On... no other options.
Hi -
When you power up your camera,
dial the top dial to the "P" choice
for programming. You should see an "L" shape
of choices on the display.
Double-click the middle button WITHIN the circle on the back.
That will allow you to scroll through the options, including your ISO, and you can choose what you want.
You can leave the top dial on "P" to use your custom settings,
or go back to "Auto" and see if you get the results
you were wanting.
Hope that helps you!
Oct 31, 2010 | Canon PowerShot A1100 IS Digital Camera
Is there a water level setting control for the washer or does it automatically detect and control that? I wondered if the control that has the options high/med/low/hang dry/no spin(lights are on or off...
Water level is determined automatically by the load in the machine. A pressure switch senses the water level after the clothes soak up all they can and just enough more is added. The settings as you suspect are for the spin speed.
Sep 22, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Please help - dial lock of cordless panasonic issue
This worked on my KX-TG3611BX and might work on yours:
Turn the dial lock off using the following method: 1 {MENU} --> {#} -> {2} -> {5} -> {1} 2 Press {*} -> {7} -> {0} -> {0} -> {0} 3 {Save} -> {Yes} -> {OFF}
Mar 28, 2008 | Panasonic GigaRange KX-TG2432 Cordless...
Speed dial not working
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Maytag Neptune MDE5500AY Electric Dryer Logo
62 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
