Question about Mitsubishi VS-50805 50" Rear Projection Television
Mitsubishi vs-50805 i have a mitsubishi vs-50805 that shuts down after about 3mins or so. ck'd convergence ic's there ok. ran signal gen to ck pic and sound all ok. but it keeps shuting down. could really use some help on this one. please e-mail with any fixes to bigpappy83@hotmail.com.
My 50707 just went to the shop after it would go into protection mode, worked over a weekend, and then totally died. My technician said that Misubishi may have overfilled the coolant gel in the CRTs when they were first made, and that the gel dripped right on a board where it caused problems. Mitsubishi is looking at my board now to see if it can be fixed. Not all the components on the boards are available anymore. The technician also said that Mitsubishi is recommending that non-flammable drop cloths be added in the cabinet so that any drips will hit the cloth and then be directed to drip off into the bottom of the cabinet where it won't do any damage.
Posted on May 29, 2007
    President:
  • 3,130 Answers
Then your not makin any money!! LMAO!!!
Posted on Jul 12, 2006
    Problem Solver:
  • 7 Answers
You said you checked the convergence ICs and they're okay - WHAT did you check? Check temperature. Also, try rapping on the heat sink they're mounted on, see if that shuts it down or causes flickers in picture. If those provide no further insight, your problem is bad capacitors on the power supply/waveform generator/deflection board, you will need ESR equipment to check them and good soldering skills to replace. Unit will require in-shop service. A repair bill over $250 is a swindle - we did one for half of that last week.
WHEN SETTING CONVERGENCE, BLUE WILL NOT GO UP OR DOWN BUT WORKS SIDE TO SIDE
Hi astump,
Welcome to FixYa.
My name is John.
I will be assisting you with you issue.
It,s time to replace your CONVERGENCE IC,s.
If you can solder, and have a good steady hand, and can be guided,
you can land this job. Post back if you want to do this and I
will let you know what tools and step are needed.
Thanks for choosing FixYa.
John
Jan 06, 2011 | Mitsubishi VS-50805 50" Rear Projection...
Tip
Mitsubishi Convergence IC Part Number List
As there has been some serious errors made in identifying the IC's for Mitsubishi Convergence, I have posted the complete list for your use.
Mitsubishi Convergence IC Part # List (complete)
Ref # / Part # / Part Name & Description
CHASSIS: VZ7
MODELS: VS-45605 / VS-50605 / VS-50705 / VS-55705 / VS-60705 / VS-70705
IC8C01 267P141030 HIC- STK392-110
IC8C02 267P141030 HIC- STK392-110
CHASSIS: VZ8
MODELS: VS-45607 / VS-50607 / VS-60607 / VS-50707 / VS-55707 / VS-60707 VS-70707
IC8C01 267P141030 HIC - STK392-110
IC8C02 267P141030 HIC - STK392-110
CHASSIS: VZ9
MODELS: VS-45609 / VS-50609 / VS-55609 / VS-60609 / VS-60719 / VS-70709
IC8C00 267P155010 HIC - STK393-110
CHASSIS: VZ6-V15
MODELS: VS-70803 / VS-80803 / WS-65903 / WS-73903
IC8D01 267P120010 IC-H STK392-040
IC8D02 267P120010 IC-H STK392-040
MODELS: VS-50800 / VS-50803 / VS-60803
CHASSIS: V16
MODELS: VS-50805 / VS-60805 / WT-46805 / WS-55805 / WS-55905 / WS-65905 / WS-73905
IC8D01 267P120010 HIC - STK392-040
IC8D02 267P120010 HIC - STK392-040
CHASSIS: V17
MODELS: WT-46807 / WS-55807 / WS-55857 / WS-55907 /WS-65807 / WS-65857 / WS-65907 / WS-73907
IC8C01 267P150010 HIC - STK392-570
IC8C02 267P150010 HIC - STK392-570
MODELS: WS-55908 / WS-65908
CHASSIS: V18
MODELS: WT-46809 / WS-55809 / WS-55819 / WS-65809 / WS-65819
CHASSIS: V19
MODELS: WS–55859 / WS–55909 / WS–65869 / WS-65909 / WS-73909
IC8C01 267P155010 HIC - STK393-110
CHASSIS: V20B
MODELS: VS-A50 / WS-A48 / WS-A55 / WS-A65
CHASSIS: VK20
MODELS: WT-42311 / WT-A42
CHASSIS: V20
MODELS: VS-50111 / VS-60111 / WS-48311 / WS-55311 / WS-55411 / WS-65311 / WS-65411 / WS-73411
CHASSIS: V21
MODELS: WS-48511 / WS-55511 / WS-55711 / WS-65511 / WS-65611 / WS-65711 / WS-65712 / WS-73711 / WS-B55
CHASSIS: K20
MODEL: WT-42313 / WT-42315 / WT-42413
IC8C01 267P173010 HIC - STK394-250
IC8C02 267P173010 HIC - STK394-250
CHASSIS: V22
MODELS: WS-48313 / WS-48413 / WS-55313 / WS-55413 / WS-65313 / WS-65413
CHASSIS: V23
MODELS: WS-48513 / WS-48613 / WS-55513 / WS-55613 / WS-55813 / WS-65513 / WS-65613 / WS-65713 /
WS-65813 / WS-73513 / WS-73713
CHASSIS: V24
MODELS: WS-48315 / WS-55315 / WS-65315
CHASSIS: V25
MODELS: WS-48515 / WS-55515 / WS-55615 / WS-55815 / WS-65515 / WS-65615 /WS-65815 / WS-73615
on Oct 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have audio but picture blacks out
You may have a bad ground on your vertical IC to begin with! Other repairs would include a bad ground on a coil or the horizontal transformer. The biggest problem is, Yes you have some bad grounds. Repair will be, to find the cracked rings underneath the boards and resolder. Take this note to your local TV Tech, this is your best defense in keeping the the repair cost down! Knowledge, in this case, is on your side now. Good Luck in your search!
Jul 03, 2010 | Mitsubishi VS-50805 50" Rear Projection...
I have a mitsubishi VS-50801 rear projection TV that has a very distorted and glichy picture
Ur tv convergence are dead.Ur tv convergence board require changing the 2 STK convergence ICS,and some or all it resistors.The shop will cost u $300-$350 for parts and labors.
May 19, 2010 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi VS-50805 HD 1080 Series
check the convergence ic's unplug the main convergence board plug then try the set again if the set comes on get a convergence kit here
http://www.tvrepairkits.com/xcart/home.php?partner=larry
May 16, 2010 | Televison & Video
I have a mitsubishi model vs-50805 projection tv and my picture has a 3d effect u can see the letters in the menu in 3 colors
the problem with this unit is in the convergence ic's need to replace and check for bad resistors and pico fuses in the circuit
Jan 25, 2010 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi projection tve problem
try resodering the convergence amp ics.That model has been known for bad solder on the convergence ICs
Jun 14, 2008 | Mitsubishi VS-50501 50" Rear Projection...
MITSUBISHI VS-50801 50" TV
Bad convergence IC possible - It's cheap if you do it your self, expensive if you take it to a repair shop. My Toshiba finally came on and stayed on after the IC's burned completely up and smoke poured out the back. Then mine stayed on with a distorted image. A good place for parts -> http://www.electronix.com/catalog/default.php/cPath/6
Apr 29, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Suddenly convergence problem
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 31, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50805 50" Rear Projection Television Logo
424 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
