Question about Kitchen Ranges
Error code f2-e1 kitchenaid superba - Kitchen Ranges
  • 4 more comments
  • Astrodog1 Nov 22, 2008
    error code f2:e1 comes on my 7 year old Kitchen Aid Superba electric range followed by a constant beep beep beep!
  • linenwell Dec 15, 2008
    I have this error code as of 5 minutes ago, and the oven controls are now locked up. I was only using the stove.
  • kriser Dec 16, 2008
    I get F2E1 periodically. It clears after a hwile, but of course is a problem when the family is over and dinner is in the oven. Now it seems as the thermostat is going too. The board says it is at 350, but the thermometer inside is at 200.... I though Kitchenaid was a good name.
  • jens144 Jan 13, 2009
    My kichenaid gas range  has the same code F2:E1 showing, all controls are locked and won't budge!  I'm thinking mine is a 2002 model.  Any ideas?
  • Tishag Mar 13, 2009
    I have the same problem and this is just a comment. Since this almost seems to be a common error, do you think that the manufacturer would do some kind of recall or compensate the owners of the malfunctioning range?
  • Sylvia Lin Jan 21, 2012
    I own 2009 model of Kitchenaid gas range KGSS907, all the paint was peeling off only six months of use it, but the most annoying thing was getting the error code F2E1 all the times, I have to manually keep shut off every hour, to get rid of the error code, otherwise it would kept beeping, nothing I can press on any of these buttons to take care of this problem, during the day I can still ignoring this type of the noise, but in the night time no one can sleep in the house, I have to unplug the electricity to keep this stove quite, is anyone outhere have the same problem to share your story, and how did you took care of this error, any advise will be very much appreciated
I had this problem 2 days ago. Shut the electrical power of the range for 15 sec, than press cancel. Otherwise, call Houston!
Posted on Mar 19, 2009
I turned off the power for a 30 seconds and everything went back to normal.
Posted on Jun 10, 2010
Press quickly, and at the same time: STOP and OFF
Posted on Jan 18, 2010
This is not exactly a solution, but it does explain what F2:E1 means. According to this page, it is a control panel malfunction. It may be caused by a shorted wire, but it may just be the control panel malfunctioning on its own.
I don't have the constant beeping like Astrodog, just 3 beeps when the code first displayed. Stovetop burners still work, oven controls remain locked and unusable.
Posted on Dec 16, 2008
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: oven buttons is not working code F2:E1 is showing on oven
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Posted on Oct 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code f2:e1
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#%^
Kitchenaid Superba Gas oven and cooktop. I frequently get a F2: E1 code, which goes away when I reset the fuse. Also, the 1, 4, and 7 touch pads don't work but all others do.
You have a bad touchpad. The ribbon cable is a failure point on all of these whirlpool built ovens. Enter the model number in at this link and see if they make a replacement keypad for your oven: Introducing the Ledgestone Technologies Touchpad
Aug 25, 2016 | KitchenAid Architect II Superba EQ Series...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have a kitchenaid KEMc308 Superba Electric oven and micowave combo. Just had the light &door spring replace. Now, it gives code F2 E0 for 60 second and then give code F2 E1. I checked the key...
If you're searching for an obsolete keypad for a Kitchenaid Oven/Microwave unit, FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order.
Feb 02, 2015 | KitchenAid Ovens
Kitchenaid superba f2e1. I have no idea what happened. I was cooking and then this code came up nothing works now. any suggestions?
Hi
F2-E1 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | KitchenAid KESC307 Electric Kitchen Range
Error code of E1 F2 on a kitchenaid double wall oven. What does that mean?
F2 - E1
Keypad cable unplugged
1.
Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace
keypad (also called touch pad or membrane switch). Some models incorporate
keypad in to control board as one unit. In this case, replace control board
(also called ERC or clock).
Feb 15, 2011 | KitchenAid KEBC207 Electric Double Oven
Kitchen aid superba f2:e1 problem, how do you fix it?
Nov 04, 2010 | KitchenAid Ovens
Oven buttons is not working code F2:E1 is showing on oven
Feb 19, 2010 | KitchenAid KGSA906PSS Gas Kitchen Range
Error code f2:e1
Feb 16, 2009 | KitchenAid KESC307 Electric Kitchen Range
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Error codes on kitchen aid range
Hi.
F2 E1 is a keypad connection error.
Here the complete list of Kitchenaid error codes:
Troubleshooting KitchenAid oven, range and...
Feb 11, 2008 | Kitchen Ranges
Kitchen Ranges Logo
9,970 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
