Insignia ns-lcd32 powers on, no AV, no response to buttons or remote (other that the on/off) I can see the backlight...Any ideeas?
  • Cosmin  Capraru
    Cosmin Capraru Oct 22, 2008
    I measured the power output from the power supply to the DSP board assembly and I get approx 3V.
    Is the DSP the main board or there is another board ?
    Thanks
  • Cosmin  Capraru
    Cosmin Capraru Oct 23, 2008
    Where do I get a replacement main board ?
  • 61 Answers
Bubulica2000,
There is two reasons to have no display on your screen.
1.LCD panel itself is deffective.
2.Main board(mother board is Deffective)
How to recoganize the problem?
There is 5VDC going from main board to LCD invertor ( different model different pin so I am not able to tell which pin or Jack is)
Check while unit is ON mode it should read in between 3VDC to 5 VDC.If this volt is correct your LCD panel is Deffective.If no voltage appear in this pin Simply change Main board(mother board)
Dont forget to rate!!
GoodLuck
Dals123
Posted on Oct 21, 2008
Where is the location of T CON board on NS LCD32
Cheryl, I will post links to what the T con board looks like so when you remove the rear panel from TV, you will be able to compare and find it easily.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
INSIGNIA NS LCD32 Con Board LC320W01 SLA1 6870C 0142B 2L
Amazon com INSIGNIA NS LCD32 CON BOARD CPT 320WF01C SD Electronics
Mar 23, 2016 | Insignia NS-LCD32 LCD TV
How can I reset my insignia tv #NS-LCD32 to global volume unlock with a RCA universal remote
Try this solution by another user:
timyorba 1 solutions Jul 21, 2011
So, For anybody who doesn't know yet, you do not need the factory remote to restore button functions to your Insignia IS-LCDTV26. All you need to do is program a universal remote that can power on and off the TV, then
"**press the "MUTE" Button 10 times successively**"
and Voila! Unlocked, you should see the status appear in the corner of the TV if everything worked, if not try another tv code or try the manual search function on the remote to find another compatible code set.
Dec 26, 2012 | Insignia NS-LCD32 LCD TV
Need to setup my tv #NS-LCD32 have no remote
You are going to need an original remote for that set.
Dec 20, 2012 | Insignia NS-LCD32 LCD TV
Insignia NS-LCD32
Most likely either the main board (processes all signal) or even an issue with the power board (supplies wrong voltage somewhere).
In either case not cheap.
Mar 23, 2012 | Insignia NS-LCD32 LCD TV
Ns-lcd32 won't turn on remotely or manually
Service manual:
http://www.my.electronicshelponline.com/uploads/Insignia_Xoceco_LC-37HV41_NS-LCD37HD-09_LCD_TV_SM.pdf
Check the power supply module.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Sep 27, 2010 | Insignia NS-LCD37 37 in. LCD TV
Purchased model NS-LCD32 second hand with no
Since you are getting the signal from the satellite, leave the satellite receiver ON and press input on the TV buttons until you get the signal back, wait 2 seconds after pressing the input button. Make sure the TV is on channel 3 if you are using the antenna input.
Let me know if you need further assistance.
Jun 13, 2009 | Insignia IS-LCDTV32 32 in. Television
My Insignia NS-LCD32 TV won't power on. The remote has good batteries, the outlet has power etc. Insignia says to unplug it it for a few seconds and then plug it back in. I tried that multiple times w
The power surges have probably blown the fuse in the power supply board. This may not be the only problem.If you are still under warranty, you will need to have it serviced at a service center. If not You will need to find a repair person or center to open the unit and test it for you. This television and all your electronic equipment should be protected with surge protectors. The reason is your power company has problem with power outages and this will damage your equipment. There is no built in self defense for this equipment due to the huge variants involved with power companies. You should call Insignia and ask them where you can find a authorized service center. You can call the Insignia customer support at this telephone number 1-877-467-4289. Tell them the model number of your television and the problem you have had with its failure to turn on.They will be able to help you find a service center to test and repair your television. I hope this information helps you with your problem.
Jun 03, 2009 | Insignia IS-LCDTV32 32 in. Television
INsignia ns-lcd32
Yes..Do you have the part number?
Oct 10, 2008 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
423 people viewed this question
Top Televison & Video Experts
