7 year old sony projection tv. suddenly multiple video inputs stopped working. only one input works but no sound. no video even off cable.
  • 2 more comments
  • ctumpkin Oct 21, 2008
    kp46wt500 thanks
    thanks for the quick reply.
    i will call a repair man in the morning. if it cost much i will just by a new one. they are smaller and better now. thanks again.
    thanks for the input. called repair guy. i'll get back to everyone when i find out the problem
  • ctumpkin Nov 08, 2008
    $90 to come look at it. took about 15 minutes tops. yes it was the "A" board i believe. $383 more dollars to fix it. i found a vizio 46 inch lcd on clearance for 800. i bought it. have a friend who will pay to get the tv fixed plus move it. everyone "wins".
    thanks again
  • 77 Answers
Sounds like the board has gone bad if there are multiple imputs messing up. depending on how much you want to spend to save the tv and the availability of the parts, it might be worth it.
Posted on Oct 21, 2008
  • 6,487 Answers
Can you please provide us the brand and model of this unit so we can help you better with your concern...
  • Mark Gil
    Mark Gil Oct 21, 2008
    There can be a problem with the board that's why the multiple input are not working the solder may got loose , and this unit is still worth taking to a repair shop and have it repair it wont cost you that much....
  • Mark Gil
    No problem feel free to contact us back in the future and if my solution is OK please accept and rate the solution accordingly thank you..........
I have a Sony Wega DLP with no sound through HDMI all of a sudden. Can't give exact model at the moment but it is a projection TV definitely 5years old at least. It has only 1 HDMI input and I've been...
The first step, and you hinted at it already, is to check cables and connectors. Especially with any electronics that old, connectors go bad if the wiring is moved, wiggled over time.
What you could try, since your WEGA is an older unit, is to connect your peripheral devices through the Component Inputs to your TV- at least one unit and see if the problem is resolved. Then you know for sure its either a cable or a connector.
Next step- try another HDMI cable and see if the sound comes back. If not, then its either the connector or the internal TV amplifier.
To troubleshoot the question on the amplifier, take a "Line Out" off your TV and run it to a stereo to see if audio is coming through. This is a lower level signal and doesn't rely on the higher power transistors required for a TV amplifier. If the Line Out audio works, then you know the TV amp needs repair.
Keep us posted!
Chad
Jun 25, 2017 | Televison & Video
Our tv, model 42hp25bat, has been running on our cable input for the past year. All of a sudden the tv input setting says "no signal". The tv works for our DVD player on HDMI setting. We...
the signal input on the cable connection to to your tv (inside your tv) is broken, and possibly needs to be replaced. Possibly few capasitors or other parts might need to be replaced. or the whole signal board.
Apr 17, 2008 | Televison & Video
My Sony KP-61v90 has just stop showing the picture from the cable input. I can hear sound but I don't get any picture. I can see video from the video inputs but nothing from the cable port. What could...
This set should have 2 RF inputs. Try hooking up to the B input and program the tuner again...
Let me know how that works for you.... Sincerely HDTV GURU JAY
Mar 16, 2011 | Sony KP-61V90 61" Rear Projection...
My Toshiba model number 51H83 has picture but no sound. I put a dvd in and the sound worked but when I went back to TV no sound. I dusted the back of my tv yesterday and since then have had no sound. Tv is...
Are you using the rf antenna input for TV or 1 of the VIDEO inputs from a cable box or sat receiver. If the latter check to see if you unplugged the audio fron the box White and red wires from box. If thats ok Plug that dvd player into that input using the cabes from the dvd player .If you now have sound change ables from box. if still no sound cable box bad. If still no sound from that input check for solder connection on input jacks. If antenna input is used replace the tunner intv.
Mar 25, 2010 | Toshiba 51H83 51" Rear Projection...
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
Sony KP46WT510 picture goes back and fortto horizontal color bars
The pictures show the result of a bad terminal input board. You can verify this by checking the inputs. Connect devices to the board and try different inputs. You will most likely find this problem on the tuner and component input were your DVI and composite video will be ok. If it is the same on all inputs replace the A board
Jun 24, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi 50V720 No sound with HDMI - no Component video inputs
Right now there seems to be many people with the same TV problems with sony and HDMI cables. Most of the solutions are resetting the TV and sony product. Try leaving your TV unplugged for a hour to let it reset itself.
Feb 17, 2009 | Hitachi 50V720 Television
Denon AVR-587 Television input stopped - no sound
try plugging another device into the tv input and mank sure you have the input mode is set to auto if you still have no sound those inputs are gone
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-587&imageField.x=106&imageField.y=8
Feb 08, 2009 | Denon AVR-587
Sony 57 Inch XBR 2001
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Dec 04, 2007 | Sony KP-57XBR10 57" Rear Projection...
NO Picture On 2 Video Inputs ( 1 front 1 rear ) : Sound OKAY
Since it is 5 years old mostly dry soldered appears. First sort out the soldered problem. Then check zener diode in video input path is short. Mostly the diode is short. Still get problem check video switching ic also. I think former is the most problem.
Dec 13, 2006 | Sony KV-36FS12 36" TV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
