Question about Yahoo Messenger
Download Yahoo Messenger 9
I cannot sign in to yahoo messenger 9 after i download it im using home vista giving me a error code 81003005 wat do i do
My yahoo messanger 9 is not workin after i download it
Posted on Oct 29, 2008
  • 507 Answers
Make sure messenger is off, then go to regedit then open up HKEY CURRENT USER then open up SOFTWARE then open up MICROSOFT then open up WINDOWS then open up CURRENT VERSION then click on Internet Settings but dont open it just click on it then go half way down the list to find PROXY ENABLE,PROXY SERVER,PROXY OVERRIDE then click on PROXY ENABLE click modify binary and change from 0x00000000 (1) to 0x00000000 (0) then delete PROXY SERVER and PROXY OVERRIDE and there you go sign into messenger this has worked perfect for me hope it does for you.
or
It's either one of the two:
- Yahoo! servers are down for maintenance, the only fix would be to wait.
- Your connection preferences are wrong:
Messenger tab just above where you sign in and then click the Connection Preference option
Posted on Oct 22, 2008
Yahoo messenger error code 8100 3005 to start
i got this problem at sign in yahoo messenger 9:81003005
Mar 09, 2009 | Yahoo Messenger
81003005
try two things.
Go to internet options in your explorer. Go to Connections tab and click open lan settings make sure your proxy server is unchecked. than click ok and try again.
If not
this will work.
Uninstall messenger(i know pain in but), and download the new version http://messenger.yahoo.com/
save it instead of just running the program, install it and try it that way.
That is usually and update or proxy error.
Good Luck let me know.
Feb 15, 2009 | Yahoo Messenger
Yahoo messenger 81003005 problem
To get away from errors you need to use YM8.1
Messenger "9" 1st version was in Beta (testing) form. The newest version is not, But it's not working well either. Stick to 8.1 until they work out the Bugs. Including people using 8.1 trying to message ones with 9 or reverse they are having compatibility problems; like text not showing,pictures not showing. It shuts down on Vista users , not allowing people to log in.Web cams do not always work. Many things do not work or are missing that YM 8.1 has. It Seems for Vista users it is so buggy Yahoo is giving up on it and are no longer trying to fix it. http://www.ymessengerblog.com/blog/2008/...
Download 8.1 here;
Yahoo 8.1: http://www.soft32.com/download_30.html.....
Use this method: Start,My PC, C drive, open Program files.Next open Yahoo file then Messenger file.Click on UNWISE to Un install messenger 9 completely. Do not just delete yahoo file as this can cause problems with other Yahoo programs.
Your contacts list and messages are stored online and will be there when you return to 8.1 messenger.
Another big problem is with the latest update for Flash Player
Flash player 10 Does have conflicts,and 9's latest update 9.0.124.0 Can have conflicts with Yahoo(very rarely, if you are using it with no problems keep it) and is causing some Yahoo Messenger services to not load.Use the link below for a download of Flash player #9.0.115.0 It should work as it's the latest before 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel, then download the older version.
http://www.soft32.com/download_500.html....
More help can be found here; http://www.freecreed.com/userid.html...
3 weeks ago
Source(s):
Soft 32 is showing "errors" on the link. updated links;
Download 8.1 here http://www.filehippo.com/download_yahoo_...
http://www.adobe.com/support/flashplayer...
Nov 28, 2008 | Yahoo Messenger
Please try again a little bit later (81003005)
hi,try the solution posted on this site:
http://stephenhaim.com/resources/yahoo-messenger-81003005-error
please give me a good rating if solution works for u.
Thanks for using FixYa.
Nov 22, 2008 | Yahoo YHT-630 System
Signing in problem with messenger: 81003005
i have a problem error 81003005 how can i remove that error ?
SOLUTION
Make sure messenger is off, then go to start>run> regedit then open up HKEY CURRENT USER then open up SOFTWARE then open up MICROSOFT then open up WINDOWS then open up CURRENT VERSION then click on Internet Settings but dont open it just click on it then go half way down the list to find PROXY ENABLE,PROXY SERVER,PROXY OVERRIDE then click on PROXY ENABLE click modify binary and change from 0x00000000 (1) to 0x00000000 (0) then delete PROXY SERVER and PROXY OVERRIDE and there you go sign into messenger this has worked perfect for me hope it does for you.
Sep 28, 2008 | Yahoo Messenger
81003005
my yahoo messenger cannt singn in . due to error code 81003005.plz help me. how my messenger open.plzzzzzz
Sep 16, 2008 | Yahoo YHT-630 System
I have a problem error 81003005 how can i remove that error ?
You could try uninstalling the messenger and then doing a clean download and install(meaning make sure when you download that all of your running programs are turned off, including your virus control.) Also, you might want to check your virus control under interent content or whatever yours may call it and see if you have been prohibited from using yahoo messenger there. Someone may have accidentally prohibited any chat or messenger programs. Good luck and let us know with a rating. thank you.
Aug 13, 2008 | Yahoo YHT-630 System
I cant signin in my yahoo messenger
I CANNOT CONTINUE ON USING YAHOO MESSENGER, ONCE I WAS LOGGED IN, ITS SAYS THAT ERROR CODE 81003005... HELP ME PLEASE....
Jun 20, 2008 | Yahoo YHT-630 System
Yahoo Messenger Logo
272 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
