Question about Whirlpool Duet GHW9150P Front Load Washer
Rattling noise during high speed spin
My whirlpool duet washing machine rattles loudly during high speed spin. It has become progressively louder as it previously sounded like a repeating ticking sound (one tick per revolution which has now become two ticks per). The maching does not make any ticking or rattling sound when the drum is rotated by hand.
  • 1 more comment
  • westworld Oct 21, 2008
    Correction: The machine does make the same double ticking sound per revolution when the drum is rotated quickly by hand. For those with the same problem my unit is Model #GHW9100LQ1.
  • Anonymous Mar 25, 2014
    I have a LG clean master
  • Anonymous Mar 29, 2014
    Beko machine has suddenly started making a noise similar to a severe rattle like something is stuck in there
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Posted on Oct 21, 2008
  • Ron Coons
    Ron Coons Oct 21, 2008
    i would then think you might have something stuck between the tubs, ie, bra under wire, nail/screw. try shining a flashlight into the tub and look for an obsruction.
Loud humming or buzzing only when it spins at high speeds
This noise causes by the drum bearing is getting worse. As soon as the noise is getting far louder and extremely louder then you have to replace the bearing of the outer drum. Normally, the repair cost is as high as buying a good deal new washer.
Oct 14, 2013 | Whirlpool Duet 4.0 cu. ft. Washer
Whirlpool - MOD WTW 6600SW1 SER - CT 4270227 Type 580 For the past several weeks, the washer became progressively louder during the spin cycle and it sounded as if there was something rattling such as...
Sounds like you have change in the pump the coin may be stopping the propeller of the pump not allowing it to pump out the water. you may be able to take the pump off and clean the pump if the propeller is too bad you may need to replace the pump the pump part number is W10049390
Jul 15, 2011 | Whirlpool Washing Machines
We have a Whirlpool Duet WFW9400SW02 that is making loud noise during the high speed spin cycles. It is only 13 mos old. Whirlpool will not even stand behind the parts. The repair person estimates over...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Very noisy when on spin. The machine seem to be balanced however the noise on spn is like a jet taking off. it gets louder as the spinning speed increases.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Mar 28, 2010 | Maytag Washing Machines
Very loud rumbling noise during spinning
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking and loud noise and rattling on final spin cycle
Turn the drum by hand and if you hear any noises it is the rear bearing. If there is no noise then remove the front bottom panel and take out the coin trap on the pump and check those hoses.
Eric
Aug 27, 2009 | Whirlpool GHW9150 Front Load Washer
My whirlpool duet washer is making a funny noise
try removing the top cover to the unit, 3 screws across the back. after ermoving check to see exactly wehre noise is coming from. some times a solid "smack " witha screwdriver will quiet teh dispensor motor if needed
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rattling noise during spin cycle
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
My Whirlpool Duet washer has started to make much more noise in the high speed spin mode, is this normal or is it a service issue?
A loud, roaring noise in high spin speed usually indicates the tub bearing is failing. A large job best left to the professionals.
Jul 04, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
1,812 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
