Question about Pelonis WM-HO202C Oil Filled Radiator Heater
Caution light comes on,rarely used heater. any thoughts?
Pelonis heater 1500 watts. caution light comes on rarely used oil filled heater. do you have anmy suggestions. we bought 5 of these 2 are working.thanks taryn
  • 4 Answers
MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Before I explain, let me clear this myth up: this is NOT an issue with the pendulum safety switch (some mistake that for a "mercury" switch). To begin, unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution! Let the brake cleaner dry before you energize this device!
Posted on Dec 11, 2012
Try calling 1-866-876-4332 ext 224 for tech help, it worked for me.  I only needed a temp
setting/off switch to fix mine.
Posted on Oct 23, 2008
Ew6507l - nowhere near warm enough
only made for 400 to 600 sq feet try Eden pure heater 1500 watts than cover 1000 sq feet the oil fill heater might have a switch 600 to 1500 watt there r usually a high and low to them good luck
Dec 11, 2013 | DeLonghi 6507L Oil Filled Radiator Heater
Pelonis heater smells like burning something
Three possibilities come to mind: First, there may be some foreign objects stuck between the sections of the coils where they connect or in their individual holes, the next is that the cord or outlet in your house is getting too hot (the circuit is being overloaded, perhaps; and finally, the clincher, you have a tiny oil leak in the coils themselves.
Jan 15, 2013 | Pelonis WM-HO202C Oil Filled Radiator...
Need power cord for pelonis model 1450W Safe-T-Furnace. Looks like power cord for Model PF-1212/B6A1 might work. Do you sell the power cord for the 1450W?
You can use a replacement cord from most hardware stores as long as it has a rating of at least 1500 watts and polarized plug. Thank you.
Feb 04, 2011 | Pelonis Disc Furnace Heater
DURING A RECENT MOVE THE BOX CONTAINER MY PELONIS
The oil does not circulate or lubricat anything. It just holds heat. No harm done.
Eric
Dec 01, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
Model ho-0218 at a given time can the mineral oil be refilled
hi , i have to ask why would you want to refill it , if the heater is leaking its rarely econamical to fix the leak and repair it , most of the oil heaters ive worked on were filled with vegetable oil .
Oct 15, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
Won't heat
Is there a thermostat? where are you from and do you understand electrics? do you have a volt meter?
Dec 22, 2007 | Pelonis WM-HO202C Oil Filled Radiator...
Pelonis WM-HO202C Oil Filled Radiator Heater Logo
880 people viewed this question
Top Pelonis Heating & Cooling Experts
paulcarew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
