Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag washer mav7757aww
Does not spin, will agitate and pump.
  • Billy Jackson May 11, 2010
    need to fix machine please answer does not spin, will agitate & pump
I had the same problem with mine a couple of years ago and it ended up being the transmission was shot. Apparently this is a common problem with this washer. Google it and see.
Posted on Oct 21, 2008
No water or agitate
IS THERE A BLOCKAGE IN THE PUMP OR THE MOTHER BOARD IS FAULTY
Dec 27, 2013 | Maytag Washing Machines
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
Washer wont pump water unless in spin cycle
it is not supposed to pump water unless it is in the spin cycle. On most topload washers the motor turns one way for the agitate cycle and then the motor reverses during the spin/rinse cycle which in turn reverses the pump and causes it to pump the water out.
Oct 28, 2010 | Maytag PAV5157A Top Load Washer
Won't spin. it agitates and pumps
this could be as eazy as a saftey switch or it might be called a door switch or it is going to be in the brake assem if that is it repalce the washer good luck to you
May 02, 2010 | Maytag Atlantis MAV6000 Top Load Washer
The agitator in my washer won't agitate. I am able to pull the agitator right out of the machine
There is a high possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin. Thanks for contacting fixya.com
Nov 24, 2009 | Maytag LAT2600A Top Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Washing machine won't agitate.
Depending on type of washer, typical top load Maytag, motor turns in opposite direction for wash and spin. Your problem will no doubt be the transmission.
Nov 01, 2008 | Washing Machines
Maytag Atlantis MAV6451 Top Load Washer Logo
277 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
