Question about MSI K8N NEO2-Platinum (MS7025) Motherboard
No start-up... I just bought a new MB. I plug in the cpu, memory, HDD, DVD, AGP, front panel buttons,and monitor, power up and get nothin. Everything seems to be getting power, i can hear the HDD spinnin, the front panel lights up all the fans are going, but no signal to the monitor and no response from the pwr or reset buttons. Is this board DOA or am i missing something? This is a computer i built a few years back and have upgraded many times but this is the first time i've had this kind of problem. I bought the new mobo cause the IDE controler died on the old one.
  • 1 more comment
  • flaxon Oct 21, 2008
    i have a wireless usb keyboard/mouse combo that i am using now to type this on my wife's laptop. Same one i was using with the old mobo. As far as drivers, i shouldn't have to install drivers to the the power/reset buttons to work just have them plugged into the correct pins on the mobo which i'm sure i did cause i looked up the manual on this website. I'll get the drivers is need when i need them. Still the monitor is not getting a signal so i can't see if the computer is even running the POST ( i don't think it is beause i never hear a beep). My video card was working fine when i pulled it from the old mobo. At first i installed ever thing i could, but when i got nothing on the monitor, i powered down using the switch on the back, since the buttons on the front of the compter are not working. Then i removed everything plugged it into the old mobo, turned it on, and got a diplay, just so i would know that my video card is ok. Then i unplugged everything from the old mobo, installed only cpu, one set of memory (two 1gig sticks),ide hdd with win xp pro already installed (not that it matters right now), dvdrom drive, and agp video card (ati sapphire x1650 512mb). Monitor still says ' no signal...
    how am i going to install drivers if i can't see anything???
  • Erol Kane
    Erol Kane May 11, 2010
    did u change any keyboard usb or wireless with it and do u have the needed drivers for ur new Mobo with?
    New Friend:
  • 27 Answers
First install your graphic card drivers for sure and second check the jumpers settings on mobo after you let me know again please... and dont forget to use a non usb/wireless keyboard to get in the bios with, sometimes that does it ...?
Posted on Oct 21, 2008
Does my w3507 have an agp port
No it does not have an agp port. IT has a PCI Express Port for video cards. Its much better and faster.
Details on your machine and what it has can be found at this link. Hope it helps.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2912877&CatId=2643
Nov 10, 2009 | eMachines W3507 PC Desktop
Asus p5s800-vm MB has complete power lets monitor know
Disconnect the hard drives, cd/dvd drives and any expansion boards you have plugged into the mainboard. We want to remove as much as possible to see if we can eliminate the problem.Using the onboard video, start it up again, and see if it comes up. If it does, then its one of the items you disconnected. Power down and reattach one of the disconnected items and power up again. Did it come up? Keep in mind that we want to see the bios start up screen. Once you have attached all the items you will have found the bad component. Replace it. But lets say you didn't get a good system when you disconnected everything. Well, that narrows down the suspected bad items to: the mainboard, the power supply, the memory, or the cpu. The power supply has many voltages coming out of it, keep in mind that the drives, cd/dvd rom drives and fans use 12 volts for spin up. There are 3 other voltages used by the mainboard. I would replace the power supply next with a known good one. Then it gets a little costlier, the memory, then the cpu and then the mainboard. Stick with it. You'll find out which it is. Good Luck.
May 21, 2009 | ASUS P5S800-VM Motherboard
Emachine W2047 No BIOS Start Screen
You can test the power button. Remove the wires from the power on pins on the motherboard. Momentarily jump the two pins with a small screwdriver. If the computer starts the power button is bad. If it still doesn't start then something else is wrong. Did you test the memory? Also do all of the fans work, especially the CPU fan? It can't hurt to test with the other PSU. You know the HDD is good. Test one piece of hardware at a time and hopefully you will find the problem.
Jan 07, 2009 | E-Machines eMachines Desktop PC
Need Help !! D865GBF / D865PERC Intel Motherboard No Pictures
While the system may be emitting a memory error beep code, that obviously is not the only issue here. If there is onboard video and it isn't working, try this:
1: Unplug system
2: Open case
3: Look for the CR2032 flat watch-style battery located on the motherboard, usually around where the front panel connections are
4: Remove this battery using a flathead screwdriver to push on the tiny 'hook' of metal holding it in. DO NOT PRY THE BATTERY OUT.
5: Let system sit for 10 seconds and put the battery back in.
6: Power the system back up
What this does is drain the system's memory completely. If it was perhaps set to use the AGP video card (which isn't installed, hence no video), this setting should be cleared and you should get onboard video.
Failing this, really, your only choice is a new motherboard, or to install an AGP card and see if it works. If you don't feel like hunting down a replacement board, I'd just order a cheap AGP card. If the AGP card works, use it. If not, then your motherboard is really pooched and you'll need a new one anyways.
About the memory beep issue:
You can google memtest86 and download that program. Burn it to a bootable CD and run the memory test; it should tell you if the memory is good or not.
hope that helps!
Jan 05, 2009 | E-Machines eMachines Desktop PC
Motherboard shuts down before booting !
You should clarify this a bit more, but please make sure all of your fans are plugged in and the no jumpers are set to over-clock the processor.Also, double check that everything is fundamentally compatible.
Dec 16, 2008 | Computers & Internet
Replace motherboard. Processor socket burnt out, contact me for further support at compdoctor2005@btinternet.com
Dec 07, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
My hardware upgrade
all your using is outdated only you can use is your 40gb hdd for a new mainboard. your can go with intel core2duo cpu with ddr2 800fsb 2gb ram.
Mar 18, 2008 | Computers & Internet
Problem with installation and no display
Hi alvinkt,
I am using 5450 and it gives me voltage mismatch error and does not boot up, goes straight to BIOS. Is your board revised version with R in the end or pre revision. Could you please help me resolving this error?
Jan 26, 2008 | Intel S5000XVN Motherboard
3 long beeps of my elitegroup ecs green 320
If you cangatehr this much of information you are no less than a computer engineer. Nobody needs to build a car to change its tyre. If you arrange a spare HDD and RAM, remove the original HDD and try to install windows on that. And if problem persists do the same with RAM also. I am sure you could solve this problem yourslef.
Oct 06, 2007 | EliteGroup ECS G900 Notebook
Intel D850MV motherboard
If you hear no beeps and the led lights, and the fans stay on after striping all the components from the motherboard except for the cpu, and power supply, you have either fried your motherboard or your cpu. Its impossible to tell without more testing. I'm sorry but you either need someone to test it or you can buy a new computer (thats what I did). For about USD $300-$400 you can get a brand new computer with 500mbs of ram, 120gb hard drive and a 3 ghz cpu. If you look around you can get an even better deal.
Aug 15, 2007 | Intel D850MV Motherboard
MSI K8N NEO2-Platinum (MS7025) Motherboard Logo
127 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
