Question about Sony XM-1252GTR Car Audio Amplifier
After connecting my Sony XM-1252GTR Car Audio Amplifier it won't turn on
When i made all the necessary connection to the amp and the battery, I received no power to the amp; however, when I was connecting the rem amp wire the light on th amp flash for a second but didn't come on when fully connected with all wiring.
  • Anonymous Feb 19, 2009
    when i turn the car on, the amp comes on for a second or two then turns off. when i tried to test the voltage the amp wouldn't show it is even getting a signal.
  • 737 Answers
Hi. You should be able to turn the amp on by touching the remote wire to the B+ main power terminal. this will tell you if it is a problem with the remote from your head unit.
Posted on Oct 25, 2008
Not enough bass. should i run a capacitor.adjust my amp and what to set it at for max performance
Turn up the gain on your amp until you get the amount of bass you want or until the sub starts to distort. If you do this and you are still unhappy with the bass, you will need a bigger amp or better subs.
Dec 04, 2013 | Sony Xplod XM-1252GTR 2-Channel Car...
Can I hook up 2 single coil subs at a 2 ohm load on my sony xm-1252gtr?
If your sub woofers are SVC (single voice coil) 2 OHM each, then connecting one to each channel would make the amplifier run in 2OHM stereo Then again, if your sub woofers are 2OHM each, it would be better to connect both together in series and connect them to the BRIDGE specified speaker terminals of your amplifier making it run a 4OHM load into one channel. This will give you all the power the amp can give and still run stable. A 2OHM load into one channel will likely damage your amplifier. Do not forget to set the LPF (low pass filter)on if you are going to use the amplifier to run sub woofer/s. dreamsystems
Feb 07, 2011 | Sony XM-1252GTR Car Audio Amplifier
I cant run my 2 sony explode 12's brigde of my amp
either don't bridge it or you will have to turn the amp down.
Jan 30, 2009 | Sony XM-1252GTR Car Audio Amplifier
Car radio wiring
do you have the amp power wire connected to the power wires for the radio
Nov 17, 2008 | Sony XM-1252GTR Car Audio Amplifier
Sub size
The sub you want is ONE single 4 ohm voice coil sub that is no higher than 500 watts in power but more than 350 watts. Your amplifier puts out the most power in the bridged state at 4 ohms so this is why you want a single 4 ohm voice coil sub. Also, you don't want to over or under power a sub so you want your sub to match or come close to your rated value of the amp. Good luck
-Andrew Hawkins
Sep 25, 2008 | Sony XM-1252GTR Car Audio Amplifier
Sony Xplod 1200w
Either the speaker is shorted out (blown), or the output transistors in the amplifier are bad. Try hooking up another speaker to the amp. If it plays, the amp is good. If not, then the amp is bad.
May 22, 2008 | Sony XM-1252GTR Car Audio Amplifier
Nothing happening
Check your power and ground connections thoroughly. Also, check your remote turn-on connection. To test it, short the remote and the +12V connections together at the amp. This should force the amp to turn on. If all of the connections are good, there may be an issue inside the amp that will need repair.
Mar 27, 2008 | Sony XM-1252GTR Car Audio Amplifier
Sony XM-1252GTR Amplifier
Can it power the subs? Yes.
Can it make them crank? Well, that all depends on your expectations. That amp/sub combo is going to give each sub about 125W, which isn't much. But if it's what you have, it's better than nothing. You might also consider using only one sub and bridging the amp. This would put about 340W on the one sub, which is much more reasonable.
Mar 13, 2008 | Sony XM-1252GTR Car Audio Amplifier
Sony xplod
No you can not fix this yourself. If the amp is blown. But did you check all the fuses? And the remote wire connection?
Jul 13, 2007 | Sony XM-1252GTR Car Audio Amplifier
Sony XM-1252GTR Car Audio Amplifier Logo
184 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
