Question about Philips E-Box FTR9965 DTV Receiver
Signal from HD cable box occasionally gets scrambled/black out
The signal will either get scrambled or completely black out when a special visual effect is shown on a channel, or certain types of commercial. I tried changing HD cable box, but that was not the problem.
I have had the same problem with Comcast and Dish Network HDTV receivers (center mode icon comes on then screen blacks out for a couple seconds - happening more often during commercials). As suggested I changed the video resolution in the set up menu of the receiver and did not experience the problem any more.
Posted on Jan 05, 2008
Try removing 1080i from your list of available video resolutions in the setup screen of the Plasma display. If you are using a HD satellite receiver, check the LEDs on the front and note if the device is slipping into 1080 mode when the probem occurs.
Posted on Dec 27, 2007
SOURCE:
HL-P4663W - picture is scrambled - tv problem or cable box problem? have directv hd
Tries tv and box unplug,replug back like an hour later.The box now should have it software updated and tv resetting itself.Tv shoud be working again.Still have the same problems,tv the cause main tv Tuner signal board is dying.Get an estamate from shops and get it repair.
Feb 18, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
My hd cable box works great in all of the video in connections on the tv, but my dvd player, hd camera do not work when I plug them in, the picture is like it is scrambled, but if I plug the cable box in...
Are you connecting these devices to the ColorStream inputs?
If so you will need to set the output settings on the DVD player or your camera to 480i. You have an HD capable TV but it is old technology and is not capable of handling the signal levels produced by HD equipment these days.
Look at the menu options on your equipment and most of them have the ability to put out the lower level signal or just hook them up using the standard yellow/red/white inputs. Hope this helped.
Good Luck..
Dec 10, 2009 | Toshiba 36HF72 36" TV
Hdtv qam tuner
More often than not the problem is with the Cable co. They ALWAYS blame the tv. I have had many many problems with the signal quality coming from that co. Here is the most likley cause. The cable signal is probably very Weak. This can be caused by a weak signal coming from the cabls co. or a bad cable inside your home. The age of the cable can effect the signal quality.Note: The cable co is only required to provide a Digital signal. Some companies allow free HD signals and some charge for that signal. The correct approach to this issue is to get with the Cox and ask the if they provide free Hd channels without a box. If they say no then you will have to get a HD cable box to watch HD programs. Themn if they say yes then you need to ask them to send out a tech and test the signal coming from the Head End all the way to your set. If the signal flucuates then you will get inconsistant scanning results.
Jul 04, 2009 | Samsung LN-T4665F 46 in. LCD Television
Mitsubishi WS-55809 Upconvert Stopped working
your problem is the 2hdw board is located in the signal board.
Feb 02, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
HD Picture is Scrambled, but Has Sound
I had the same problem
you have to set up the componant on DTV.
the signal my be hd 1080i and the only connection with componant that can support this is the DTV port.
the other componant connections only support 480,
good luck
Apr 06, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Is it the DCT or the cable signal?
if you are getting signal of the proper strength and quality the cabling is good.the problem is the box trying to decode the signals.a lot of signals are encripted and have to be decoded by the box.if the box is not responding fast enough you will see bloches on the tv.if you see scrambled channel you are not payinfor that channel.and if you are paying for a channel and it comes up scrambled your box is not working correct.get your company to upgrade the box.
Jan 07, 2008 | Arris DCT6200 DTV Receiver
1080i HD signal not working through COmpnoent IN
WE NEED TO ALL SEND LETTERS TO SONY ABOUT THIS ISSUE. MY PICTURE TUB WENT OUT 4 YEARS LATER AND I HAVE TO MAKE ADJUSMENT HERE AND THERE FOR THE SCREENS VOLTAGES. CALL SONY AND COMPLAIN. I DID.
PRIDAH
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Screen blacks out on HD channels
Saying that the problem is with your TV doesn't make any sense since your TV is fed from the cable box.  Your TV doesn't know one channel from the next.  If it had a problem it would effect all channels.  You may not have enough signal to the INPUT of your cable box due to a problem on the pole or at your house or both.  Insufficient signal can cause some digital channels to not get decoded properly by the cable box.  The lower channels will show noise symptoms such as what you describe but they won't crap out altogether like the digital ones.  Have a cable tech come out and measure the signals.
Do you have splitters in line with the cable anywhere?  If there's any way to beef up the amount of signal getting to the cable box try it.
Oct 15, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Problem w60 inch using hdtv cable box
i know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
May 15, 2007 | Philips 60PP9352 60" Rear Projection...
Philips E-Box FTR9965 DTV Receiver Logo
277 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
