Question about Olevia LT37HVS 37 in. LCD HDTV
Syntax Olevia 30" LCD - blue screen, then black screen, sound is on
Issue with my Syntax Olevia - When I power it on, the blue screen turns black. The sound is still working. Anyone see this before?
  • 7 more comments
  • Anonymous Oct 21, 2008
    I have the exact same problem. If you read other web sites so do hundreds of other Olevia owners. I happens just a few years after buying the television. Buyer Beware!
  • samc2 Oct 22, 2008
    I have the same problem just happened does anyone know what's going on the TV was working fine.
  • Anonymous Nov 01, 2008
    no signal blue backing and some times goes black with sound
  • Anonymous Nov 02, 2008
    same problem
  • zeebees Dec 19, 2008
    yep, same problem here after about 31/2 years of use. picture will go black. have to turn it off and back on. works for a few more minutes then black again. usually only in mornings and evenings does it have this problem. can work for 6-8 hours without going black. then when it does, 4-5 times of restarting and its back to normal.
    synatx olevia 30" LCD
  • gopher1515 Jan 06, 2009
    if the picture is still there just in wierd colors is it still a blown inverter??
    if the screen is there just in blue and red and dark colors... example: i can see that it is a basketball game and see the players outlines but I can't make out anything other than that... if this is what is happening is it still a blown inverter?
  • Anonymous Feb 27, 2009
    I have exactly the same problem when the tv was 2 1/2 years old, same with a friend of mine....sounds like a lot of people are finding this problem.
  • Anonymous Mar 13, 2009
    This Oleiva ppeople are a bunch of cheats pls dont make the mistake of buying this TV. I sent mine for repair and they repaired and sent my TV to some one else and the TV they send started to flicker after 5 months and they are dont want to do anything about it..Please dont not buy this TV
You have a broken inverter board. I have a LT30HV, and it had the same problem. The inverter board supplies power to the backlight. Swap it out with a good one, and you're back in business.
To test, take a bright flashlight and point it at the screen just an inch or so off the surface. If you can see your picture, then you have a blown inverter.
it may not be worth fixing it. Wait for a good sale on a new one. My inverter cost about 150, and it was a remanufactured part. Not as good as the original part as it flickers just a tad. I had to take the entire TV apart, with pieces literally everywhere. My cats loved it.
Posted on Nov 15, 2008
Tv wont turn at all and the blue light is not on either
you have power supply board problem (PSU)..try to replace that to fix the issue..
Oct 16, 2012 | Syntax Olevia Lt30hv 30-inch Hd-ready...
Olevia LCD HDTV 242tfhd will not turn on.
See solution above (from John Adams) if that doesn't work it may be the power board which is available on ebay for $69 incl. shipping. Good luck.
Mar 09, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Blue power light is on but no picture......olevia 537
I have a Syntax Olevia 532-b12 and ironically, the blue light is on when power is off (and turns off when the power is on...) I assume it's the same for the 537H
Feb 23, 2011 | Syntax Olevia 537H Television
Syntax Olevia LT26HVE, powers on, blue screen w/ sound
I have an Olevia LT26HV power is on stay blue, sound ok, but no display.
Dec 30, 2009 | Syntax LT26HVE 26 in. HD-Ready LCD...
Olevia 42 inch Flat Panel has power supply issue... Blue light does not come on and tv does not turn on... I have tried all different things to get tv to work with no positive results
What did you try so far? The main power supply MUST have at least the 5V standby supply section working. This 5v is used by the main control board to send out the command to turn on the main power supply section which will power up the rest of the TV circuits when the power switch is activated either by the power button of remote or on the TV powern button. Look for this 5v first.
Nov 04, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
LT 30 HV Olevia Syntax No picture - blue flash
Ur video converter board is dead.
Need to be change.
Aug 15, 2009 | Insignia 37" LCD Flat-Panel HDTV
My syntax Olevia LT30 HV turned on and displayed blue screen for 1-3 sec and than no signal nosound??any advice seems to be inverter issue.
Since you lost both sound and picture, I would suggest to take a look at the power supply for bad filter capacitors, look for bulging on the top of capacitors. If the backlight inverter board is bad you should still get the sound.
Apr 23, 2009 | Syntax LT30HV 30 in. HD-Ready LCD...
Olevia LT37HVS 37 in. LCD HDTV Logo
1,313 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
