Question about Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump...
My jacuzzi stopped turning on.
It was working fine and all of a sudden it would not turn on. I did take all the jets out and cleaned them. One problem is I do not have access to anything else. The tub is in the corner and surrounded by tile. Any ideas? I recently hurt my back and really could use it.
  • Anonymous Nov 10, 2008
    Our tub will not turn off, but I do have access to the controls, I filled the tube with water but it still won't turn off.
  • carolyn l Feb 20, 2009
    when putting insulation around my jacuzzi to stop the cold air the jets will not now turn on and I noticed the air swith tubing or hose is not connected. I cannot find a make or model. can someone tell me where the hose goes into the pump or motor?
  • 21 Answers
I would check all power to the tub. Is it plugged straight to a breaker, plugged into a GFCI, GFCI breaker in the master panel? For it to just stop altogether I would think something tripped.
Posted on Dec 01, 2008
    Problem Solver:
  • 7 Answers
If the tub will not will not turn on, of course check your power coming to the tub, next check the power at the control panel/ box of the spa, make sure it is live (hot). You state the sides are tiled?
There HAS to be an access panel of some sort to service the controls. If the access has been tiled over, you need to take your tile guy/gal out back & give him or her a swift kick in the "KEESTER" Check for an in- line fuse at the circuit board of these controls.
I have also seen a bad air switch and /or relay cause the the spa not to turn on or "off" for that matter
Posted on Dec 12, 2008
My jacuzzi won't turn off. I have to turn the breaker off so it will stop. What can I do?
Posted on Dec 04, 2008
Jacuzzi jets smell like rotten eggs when turned on.
Need to run some cleaner through jets to clean out old water and mildew.
May 09, 2010 | Home
1 set of 4 jets won't work properly?Jacuzzi 6 place tub any solutions?
check the face of the jet trim to make sure it is turned on. most jets today turn clockwise and counter clockwise to turn the water on/off on each jet.
Feb 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Whirlpool Jacuzzi with 10 jets one stopped working.
either one of ur hoses has come off or is stopped up get to the sides and see if one has come off
Feb 24, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jetted bath tub has stopped working. Motor hums
look on the back of the motor there should be a shaft that you can try to turn to spin free because something inside the pump is blocking it. rate me if this is helpful.
Feb 15, 2010 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Jacuzzi Laser II: Problem with the Heater/filter setting. The jets come on when it's on this setting. When I turn it to Filter setting it's fine..when I turn it off the jets come back on What gives?
The jets will run while in the filtration / heating mode. If the spa is in the middle of the filtration cycle, the jets will stay on until the cycle time runs out. So, if the spa jets are on during this time, they are on for the full duration, 2-6 hours every 12. You can cycle the jet button to high, but when you try to turn them off, they will just go back on low.
Jan 23, 2010 | Jacuzzi Cyget In Ground Pool Pumps
My Jacuzzi won't turn off or heat
The heater will only fire if it has water in it. If you just got the house, make sure the gas/electric to the heater is on. Turn off the pump and turn it back on.. See if that works. good luck
Jun 05, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Suddenly whirlpool action in jacuzzi tub very low
Try turning the jets clockwise while they are running and see if this makes a difference.
Jan 18, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump... Logo
3,495 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
