Question about HP Officejet Pro L7680 All-In-One Printer
Printing For some reason my printer will not print, however the network after troubleshooting is fine, it copies & sends faxs but on command it will not print even fronm my desktop! Has anyone had this experience, what's the solution?
Try clearing your print spool file
Posted on Nov 02, 2008
How can i send an ascii file to a network shared Datamax Prodigy Plus printer? It is not printing via send file, windows driver send command to printer works. Thanks for any help!
copy file.txt lpt1 is the command to copy the txt file to the printer, but it must be correctly formatted for the Datamax. I don't know Datamax's programming language, but at first glance that file looks like ZPL to me. If it is ZPL the Datamax can't print it.
Jun 15, 2015 | Datamax Prodigy Plus Thermal Printer
I am having trouble with the printer. The DR is working fine. It sounds like it is printing, however it does not. print. There seems not to be a problem with ink The printer is not printing. I...
Definitely you have a problem with the printer.
That will not prevent you from sending faxes out, but did you try to make a copy?
If the machine sat idle for some time, the ink in the jets would have dried, but this will not generate any error messages.
There are cleaning kits available, and they usually work.
May 31, 2011 | HP 1040 Plain Paper Inkjet Fax
OUR tALLY 8008 IS A NETWORKED PRINTER. FOR SOME REASON IT IS NOT PRINTING FROM MY COMPUTER. IT WAS PRINTING FINE THIS MORNING AND IS STILL INSTALLED ON MY PC. THE MESSAGE "THE DOCUMENT FAILED TO...
You may need to clear out your print que and restart the print services. Open a command window by typing CMD in a run box. Type the following in the command window after it opens:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
There will be a delay after you hit enter when you type the net stop and net start commands.
Aug 26, 2010 | TallyGenicom Office Equipment & Supplies
Canon Pixma MP190 all-in-one will copy offline and scan online however, when attempting to print online, status shows as 'error-printing'. have checked cables & power, cannot print from print command....
this sounds like a virus any ways, make sure u have a very good antivirus, remove and reinstall the printer with the driver but first go to the printer delete all the printers installed manually i.e after uninstalling the printer and its still showing the printer at printer and faxes, then reinstall it.
Jul 22, 2009 | Canon PIXMA MP190 All-In-One InkJet...
It just quit printing and copying
Hi ..
There could be multiple reasons for your printer not printing ..
1) Your printer is not setup as default.
2) Your printer drives need to be re-installed.
1) Your printer is not setup as default: If your printer is not your default printer, follow the instructions below to make it as default printer,
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.' On the screen, right click your printer and then left click on "Set as default" option.
2) Your printer drives need to be re-installed: If you have the driver CD then use it to re-install the software.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
It has plenty of ink and the drum is good but it stopped printing
All blank pages could either mean: On the scanner side: * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the scanner side by printing a test page on the printer. If it prints fine, the problem is in the scanning process.
On the printer side: * Dirty connectors between toner/drum unit and machine. Remove the toner/drum package and clean the metallic cylinders on the left and right side of the toner/drum unit, then reinsert package into machine. * Bad toner and/or drum unit. Replace should solve it. * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the printer side by either scanning to a connected PC or sending a fax to someone. If the scanned/faxed page looks fine on the pc/fax that receives the fax, the problem is in the printing process.
Jun 02, 2009 | Brother MFC 9700 All-In-One Laser Printer
Hp office jet 4255 printer not printing anything or copying
ok..first try to make a copy and check if it copies fine or not..
if it copies then hardware is working fine..
turn off the laptop and unplug the USB cable..
turn on the laptop and wait for 5mins and then connect the USB cable..once the USB cable is connected do not try printing..wait for the hardware to get installed..
and then go to the printers folder and check if the printer icon says 0 ready..if it says then try printing..that should work
Feb 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
The printer does not print when commanded
try and copy something and check if that comes out blank or not..........if it comes out fine then just follow the troubleshooting guide on www.kodak.com/go/itg .
Dec 23, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at Zebra.com
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Sep 24, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Fax Machine Samsung Model SCX-4521F
Kindly update me Is it printing/Copying working properly.
This issue with printing part. Kindly clear memory. Check Cartridges.
Sep 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
HP Officejet Pro L7680 All-In-One Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
