Question about Fisher and Paykel GWL11 Top Load Washer
Water fill does not shut off
In every cycle, the water fills and will not shut off causing potential overflow. We have checked the drain pump to make sure it is clean. We have also checked the air hose to the water level sensor for any cracks or holes and that appears ok. Could the problem be the diverter valve or the water senser? Thanks.
  • Chris Calvert
    Chris Calvert Nov 16, 2013
    Actually can that previous comment. Just found that there will be a leak when the tank is empty. I am starting to wonder if the pressure transducer is calibrated wrong.
  • 4 Answers
Or maybe there is a hole or leak in the air chamber. After checking that blowing into a pipe attached to the pressure sensor does shut off the water I decided to blow down the other tube going to the air chamber. And I could hear air coming out inside down at the bottom. With an air leak here there is no way the pressure transducer will shut off the water hence the overflow. It may be the air pipe way down the bottom or the chamber and I am off to investigate now.
Posted on Nov 16, 2013
    President:
  • 1,462 Answers
Problem caan be the pressure switch. to test it, put on a length of hose, set machine going and use your mouth to pressurize the hose and water should stop. if it doesn't then pressure switch is faulty.
also the pressure switch hose goes to an air chamber and this can be clogged with gunge
Posted on Oct 21, 2008
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
I have a brand new whirlpool wfw70hebw Duet washer that is stuck in the "draining" mode- the door is locked and the lock light is flashing red and it sounds like the drain pump is running. None of the...
I think you have a coin or something stuck in the drain pump itself. I have had to remove the pump,and take out the coin, reinstall it and it works perfect.
Jun 18, 2014 | Washing Machines
The unit overflows on an inconsistent basis. It
Check the inlet water solenoid.
Apr 15, 2010 | Dishwashers
Washing machine keeps filling and will not go into cycle
if it overflows and dosent agitate check your pressure switch and hose.if it overflows and agitates you have a bad fill valve. if it fills and pumps at the same time check your drain hose. it should be higher than the water level of the machine or it will siphon out.
Jan 23, 2010 | Maytag Washing Machines
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water leaking during drain and spin
Hi!
You Need to check the following--
The fill hoses : These are located behind the washer and are connected to the water mixing valve and faucets. Pin holes and cracks on the hoses may cause them to leak.
The water valve: The water mixing valve is located behind the washer. The fill hoses connect to the water mixing valve. Inside of the valve is that the water gets directed to the filling spout. Water leaks happens when the valve develop pin holes or cracks. Bad fill hoses or water valve could be the reason why the washer is leaking water.
The Filling spout: Is just a directing part, this part directs the water from the water valve to the tank. Pin holes and cracks is what make this part to leak.
The tank : The major cause for the tank to leak is through holes or cracks that the tank develops because of vibration or metal items hitting the tank during the spin cycle.
The tub seal : The tub seal is made of rubber, it is connected between the transmission post and the center of the tank. Leaks developed when the seal gets worn out and it looses the ability to make a good seal between the transmission and the tank. A crack tank or worn out tub seal could be the reason why the washer is leaking water.
The overflow tube : This tube is use to direct the water away from any electrical parts like the motor in case of an overflow cause by a bad water mixing valve or bad water level switch.
The pump : The pump job is to remove the water from the tank to the drain pipe. This pump has an electric motor and an impeller. When the pump motor is turning, any water that falls in to the impeller, is push out to the drain pipe.
Most leaks are cause by a worn out seal between the front pump housing and the rear one.
The drain hose : The drain hose is made of hard plastic and some times it develops pin holes and cracks leaks. Bad pump or drain hose could be the reason why the washer is leaking water.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
Rylee
Apr 03, 2009 | GE Washing Machines
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
153 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
